Civic/Integra interchangability
Old Dec 17, 2002 | 05:48 PM
Patron's Avatar
Default Civic/Integra interchangability
Basically, I want to know if 97 Integra GS-R seats will fit a 92 Civic CX. Both the front and back. I've done a search, there's differing stories. Some say you need the upper part of a 2 door GS-R and the bottom half of the 4 door. I have heard that there is gapping on the sides and the bottoms. Is this true?
Also my roommate wants to know do EK seats fit in the EH?
Old Dec 17, 2002 | 05:54 PM
JasonBlackEJ1's Avatar
Default Re: Civic/Integra interchangability (ptran13)
im pretty sure that to put the front seats all that u need is the seats and the railing. for the back seat, u have to get it out of a sedan, and it would fit pretty good except it hangs over a little bit. i did a search on it, too, and i posted something about it. this is basically what i found out. one of the guys that replied had pictures of how to do it that replied to me.
Old Dec 17, 2002 | 06:09 PM
iwhichisme's Avatar
This is what ive encountered so far. The teg seats fit perfectly in the front, and if you dont have the rails from the teg; The civic rails bolt up to the teg front seats perfectly. THe back seats are a little funny. It has been my experience that neither bottom pads from the coupe or the sedan will fit perfectly. I used the seats from a coupe. THe top two peices fit perfectly, but the bottom peice is a tad smaller than the stock civic piece. THerefore there will be gaps on both sides. i just took some blk carpet and placed it on both sides, making the gaps less noticeable. You also might need to place some towels or a blanket underneath the bottom peice to compensate for the gap that is between the bottom of the top 2 peices and the bottom peice. THat has been my experience with that mod. Hope any of this helps.
peace,
Old Dec 21, 2002 | 07:42 AM
Patron's Avatar
Default Re: Civic/Integra interchangability (iwhichisme)
You're right, the rear seats on the coupe don't work, do the seats on the sedan work? I want an answer from someone that has first hand experience with this. The front seats were a perfect fit, the rear upper half was a perfect fit, it's just the bottom half of the rear seats that get me.
Cln94EG1
Feb 26, 2008 10:57 PM
FinestImage12
Oct 20, 2004 08:32 AM
fodoteg
Feb 5, 2004 09:21 PM
conceptEG
Oct 25, 2003 10:23 PM
92CIVICCX
Jul 26, 2002 04:53 PM
