click click sound coming from engine when moving.
Old Dec 17, 2002 | 02:02 PM
TheHater
Guest
Posts: n/a
Default click click sound coming from engine when moving.
I hear these click sound at about 1000-1500 RPM and then it stops. Any Idea it sounds like vibrating but I cant find anything loose.
Old Dec 17, 2002 | 02:29 PM
ricepuddin's Avatar
Default Re: click click sound coming from engine when moving. (BOOSTINSI)
valve tap?
Old Dec 17, 2002 | 03:18 PM
Shawn C's Avatar
In The Garage
Default Re: click click sound coming from engine when moving. (ricepuddin)
my guess is that either your cv joints are wearing out (if this noise is at take-off, or while youre turning) or maybe a loose or broken motor mount bushing.
Old Dec 17, 2002 | 03:32 PM
Turbo Powa's Avatar
while driving or during idle?
Old Dec 17, 2002 | 03:34 PM
Happyman's Avatar
valve tap?
Could be. But you'd have to have some poor engine management for that to happen.
Old Dec 17, 2002 | 03:40 PM
TheHater
Guest
Posts: n/a
Default Re: click click sound coming from engine when moving. (Happyman)
It only happens at 1000-1500 Rpm and then I cant hear it. It sounds like its coming from the front . Like the wheels . Maybe its the CV Joints . How could I tell?
Old Dec 17, 2002 | 03:43 PM
AbaZ's Avatar
Well first off you need to tell us if you are just sitting their reving it up and the noise happens or if its a drivetrain problem.. as in the car is moving when the problem happens?
Click click style noises usually mean a front CV joint is going bad. Have you looked under your car in awhile? how do the outter CV boots look?
Jeff
turbopenguin
10
Sep 22, 2014 04:28 AM
plikit
Nov 14, 2005 11:18 PM
Mike banX
Suspension & Brakes
May 17, 2005 04:37 AM
civic nut
Apr 14, 2005 01:28 PM
redliner8000
Feb 19, 2004 08:49 PM
