Header for D series motors
Old Dec 17, 2002 | 01:19 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Header for D series motors
What can I expect from a dc header for a D15B2
Is it worth the 300
or as a matter of fact worth buying one for a d series at all?
Old Dec 17, 2002 | 01:39 PM
MugenHonda's Avatar
Default Re: Header for D series motors (MugenHonda)
ttt
Old Dec 17, 2002 | 01:48 PM
Malgerus's Avatar
Don't bother with a header, do an MPFI swap. You can pull it off for way less than 300, and it'll give much much more power than a header
Old Dec 17, 2002 | 01:55 PM
MugenHonda's Avatar
Default Re: Header for D series motors (Mr. S)
All the wiring
whats the easiest way to do a mpfi swap
I thought about the header and figured it wouldn't do any good anyways lol
i am gonna search
Old Dec 17, 2002 | 02:45 PM
slowman's Avatar
I took way too long
MugenHonda - Do not underestimate the D Series. Of course it's a good idea to get a header. It's the best mod i've done. But also, an MPFI swap is good too, but get both. D Series
Old Dec 17, 2002 | 02:50 PM
slowman's Avatar
I took way too long
Default Re: Header for D series motors (slowmanEF)
https://honda-tech.com/zerothread?id=348343 for the basic things you need for MPFI swap
This helps too:
DPFI TO MPFI CONVERSION
complete intake manifold (TB, fuel rail, injectors, all sensors!)
injector resistor
88-91 Si ecu
88-91 Si distributor
and an si coolant hose to connect the manifold and the block u can use ur stock and cut it if ur cheap
its pretty easy! drain the raidiator and all then take off the intake manifold and put the si intake manifold on and rewire everything. dissconect all the plugs from all the sensors and the injectors make sure u diconnect the coolant lines from the intake and there is one bolt that holds the manifold to the block underneath u wont see it unless u know about it
In order to convert your dual point injection DX to multi-point injection you will need 4 injector plugs, an injector resistor box, extra wire, and electrical tape(heat shrink is best).Also, when doing this conversion I would highly recommend soldering all connections and heat shrinking them. It is good to have an extra multi-point injection engine harness laying around to take plugs off of(injector plugs, injector resistor box plug, and distributor plug u can use ur stock dist plug if u cut one off another dx dist and use it to plug in but ull need a 2 wire plug for the ca sensor).
Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Sometimes there is a unused wire at B12.
Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step.
Run wires from C1 and C2 on the ecu into the engine compartment. Label these wires for later use.
Cut wires at A3 and A7 leave excess for later use. Run these wires into the engine bay and label them to be used later on .
Under the Hood
TPS and EACV plugs are too short and must be extended.
Be sure to switch green/white and yellow/white wires on TPS since the dx turns the opposite way.
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
Connect the yellow wire from the DX injector to the #1 injector (brown wire).
Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
Connect the A3 wire to the #2 injector (red wire).
Connect the A7 wire to the #4 injector (yellow wire).
Connect the 4 red/black wires from injector resistor box to each injector.
Cylinder position sensor
Connect C1 to blue/green wire on cylinder position sensor plug.
Connect C2 to blue/yellow wire on cylinder position sensor plug
the rest of the wires are color matched. dx to the si wires
antcrxls
Jun 28, 2012 04:20 PM
thisboyjulio
Feb 27, 2010 04:31 PM
ShAAdiiiNG
Dec 26, 2002 05:38 PM
