Different Turbo kits
Old Dec 17, 2002 | 11:14 AM
94si94cx's Avatar
Default Different Turbo kits
Ok, anyone who has read any of my posts knows that I have gone back and forth in trying to decide on an engine. I finally got a hold to a b18b swap. I just have to finish paying someone back for my car.
I want to turbo this thing with the money that I get from selling my Si. I was looking at a few turbokits, Drag Gen III, Revhard, Greddy, F-Max etc...
What are the difference between these kits and which is the best for the money. I live in Fulton Co. GA so I dont have CARB just emissions testings.
I know the Greddy kit is CARB legal and uses slightly different hardware and also doesn't come with an Intercooler. The F-Max/Drag/Revhard all seem to use identical hardware with the exception of the fuel systems and electronics. I know the F-Max comes with injectors which I like, but are the decent ones to run when pushing 10-13psi?
One less question, when I get a Hondata, are these fuel control systems that come with these kits going to be sitting in the bottom of a trash can? If so is it worth buying a kit if I plan on getting a Hondata in the very near future, possibly on the same day as I purchase my turbo?
Old Dec 17, 2002 | 11:19 AM
ImprtTuner88's Avatar
Default Re: Different Turbo kits (tealeh2)
you may want to direct this to the Forced Induction forum where all the psi heads hang out, more there to answer your question.
wish I could give you more info, good luck on your search and setup!
Old Dec 17, 2002 | 11:26 AM
AB16A2T's Avatar
Mmm turbo. Best thing to do, would be to piece a turbo kit together, that way you get the best hardware you know you can afford. Inline Pro Mani's, etc. This post is quite common in the FI section. Here is a post I replied to it has a bunch links I put in there, both for the kits and for places to get parts.
https://honda-tech.com/zerothread?id=356155
mvp97gsr
Jun 14, 2006 05:01 AM
street_mechanic
Oct 28, 2003 11:55 AM
94si94cx
Dec 25, 2002 06:00 PM
integragsr6
Jun 28, 2002 08:11 PM
