Let's talk longblocks.. H22 specific.
Old Dec 16, 2002 | 11:41 PM
ForcedAccord's Avatar
Texas B*tch!
Default Let's talk longblocks.. H22 specific.
Alright I was just browsing through some JDM-USDM engine sites and I came across where you can buy just the H22a "longblock."
<u>H22a Longblock Includes:</u>
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Distributor
<u>Full H22a Swap Includes:</u>
- Motor
- Hydrolic Tranny
- ECU (P13)
- Axles
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts
- Engine Harness
- All Sensors Needed
- LSD Tranny (Optional +$300)
From what I can get out of comparing, all that is lacking with the longblock is the ECU, axles, motor mounts, harness, and transmission.
I know the stock Accord axles should work, along with the transmission.
For someone wanting a swap soon, would buying the longblock using the stock axles/transmission be fine until funds allowed for the other stuff?
Or are there a lot of other variables that I am not considering?
Thanks in advance.
Old Dec 17, 2002 | 09:56 AM
Texas B*tch!
Default Re: Let's talk longblocks.. H22 specific. (ForcedAccord)
Old Dec 17, 2002 | 09:58 AM
ArchAngel Sabastian's Avatar
New User
you need the driver side prelude mount, and the p13 ecu
[Modified by ArchAngel Sabastian, 12:12 PM 12/18/2002]
Old Dec 17, 2002 | 10:55 AM
Texas B*tch!
Default Re: Let's talk longblocks.. H22 specific. (ArchAngel Sabastian)
Thanks for the replay.
What does an engine harness usually run for?
Same for the prelude mount, and I believe I know what I'd be looking at on the ECU.
Old Dec 17, 2002 | 01:04 PM
Nick M's Avatar
You need to resuse the Accord harness for the chassis, the Prelude one doesnt work. I know HMO will throw in an ECU and drivers side mount for an extra $300 usually.
Old Dec 17, 2002 | 02:48 PM
BoostedH23a1's Avatar
Default Re: Let's talk longblocks.. H22 specific. (Nick M)
yea use the accord harness.
also u do have to have the prelude drivers side mount and we had to slot the holes for the frount mount a little but it works.. i would wait till u have all the money at once. its a pain in the *** to pull the tranny while the motor is in there. take your time and do things right the first time.
peace..
Old Dec 17, 2002 | 09:53 PM
Texas B*tch!
Default Re: Let's talk longblocks.. H22 specific. (BoostedH23a1)
Yeah I feel you on the do it right the first time, but patience is not on my side.
That and the main reason I'm considering this is b/c I'm well past overdue for my 90k tune-up and rather than spend all the money all that, I can just put in a new engine like I've been wanting to do.
Ok... back to the engine.... when you guys say harness, in what extreme are you meaning? Like define what the harness does b/c it seems as if there are many different types, like if the longblock were an OBDI, and since I have an OBDII then I'd need an OBDI wiring harness. I just don't know how many harnesses are necessary, etc.
I think that's it for now, I'll post questions as they come, thanks for the input thusfar though, really it's greatly appreciated.
Old Dec 18, 2002 | 07:04 AM
KTeller8's Avatar
you need the actual engine harness its the full harness thats holds bout 20-25 sensor thats plug into almost every part of the tranny and engine.
the obd2-1 harness which i am sure you know i ll help you get
will plug into the ecu and allow you run obd1 thats a totally different harenss thast bout I--------I this big and the engine one is I=======================I that big.. lol
Old Dec 21, 2002 | 04:51 PM
fbiguy007's Avatar
90k i have 267,000 on my f22a with the factory clutch still
Old Dec 21, 2002 | 05:20 PM
cyrixvsp2's Avatar
Default Re: Let's talk longblocks.. H22 specific. (fbiguy007)
ok, i guess i'm stupid when it comes to jap cars. I'm still learning on them. what's the diff between a standard h22 and a long block h22? i'm seeing long blocks pop up places and they are same displacement so i can't figure out what exactly a long block is. thanks for the help.
also, fbiguy007, what accord and f22 do you have?
Old Dec 21, 2002 | 06:15 PM
niedejb's Avatar
Default Re: Let's talk longblocks.. H22 specific. (cyrixvsp2)
Long blocks are just the engine minus the tranny/axles/ecu. Same engine.
Old Dec 21, 2002 | 06:54 PM
cyrixvsp2's Avatar
Default Re: Let's talk longblocks.. H22 specific. (niedejb)
thanks for the help. that would explain why the prices are less.
Old Dec 23, 2002 | 02:08 AM
fbiguy007's Avatar
f22a6 ex coupe http://hometown.aol.com/fbiguy007/my...e/profile.html
Old Dec 23, 2002 | 04:33 PM
MrBui's Avatar
either way u should replace timing belts and all while engine is out.....
soundFX
Jul 13, 2006 11:22 PM
epidemic
Jul 18, 2005 04:58 PM
Jerry31
Jul 4, 2004 11:32 AM
ForcedAccord
Dec 17, 2002 11:08 PM
ForcedAccord
Dec 17, 2002 12:48 PM
