N/A Accords
I noticed a lot of you guys have some sort of forced induction on your cars. Where are all of the N/A accords. And how are y'all doin on the track? I myself might get a 99 accord ex soon and i wanna make sure i am headed in the right direction.... or should i get a 4 door gsr....
all motor here with a h22a in a 94 accord ...
94 accord h22a motor swap :
-areospeed intake
-dc sports header
-lightweight findenza flywheel
-ACT clutch 6 puck
-apex n-1 exhaust ( left the same clogged cat )
-ultra ss complete pulleys set
-hondata ecu chip
i just bought msd ign. msd blaster . msd 8.5 wires .. walbro fuel pump .. aem fuel rail , fuel injectors , fuel press regulator .. ported and polished the head ..
-areospeed intake
-dc sports header
-ACT clutch 6 puck
-hondata ecu chip
how many of your N/A cars run 13's and the car don't look like a gutted out bucket in side
how many of your N/A cars run 13's and the car don't look like a gutted out bucket in side 2point6's does... just give me some time man mine will too
whos accord out there does mid 13s, and what do ya got under the hood...i'm looking to see what else i can do to my accord to push it faster. 2pt6 what do you have done to your car?
[Modified by pisces21, 7:50 PM 12/17/2002]
am i sensing sarcasim?
[Modified by 2point6, 12:24 PM 12/17/2002]
Engine Block: '93 H22a "bored and stroked" to 2.44ltrs of displacement built by Collective Racing. Custom 98mm Crank (Balanced and nitrited), Darton sleeves, Crower Pro-billet rods, Custom 12/1 compression 89mm JE pistons, Prodrive oil pump, Unorthodox Racing Crank pulley, manual timing belt tensioner conversion.
Cylinder head: Ported and polished by Collective Racing, Web Cams custom camshafts, Web Cams springs and Titainium retainers, Euro Type R manifold conversion, Hondata intake manifold gasket, Erick's Racing 70-68mm Throttle body, RC engineering 440cc Fuel injectors, B&M fuel pressure riser and Guage, STR cam seal, AEM cam gears, SMSP 4-1 header, ARP head studs, SCE copper head gasket.
Misc: JDM "blue" valve cover, Dyna Batt 11lb. battery, Nology coil, AEM 3" cold air intake, Apexi VAFC, AEM underdrive pulleys.
Suspension/brakes/wheels: LSR full damper coilovers with Eibach springs 500lb front 600lb rear, Prothane bushings, Powerslot front and rear rotors, Accord wagon front and rear disk conversion, Axxis Metal master pads, Landspeed Upper strut tower brace, Goodridge Stainless brake lines, ARP extended wheel studs, 17" SSR Integrals (street) Bogart drag stars (track)
[Modified by 2point6, 12:32 PM 12/17/2002]
N/A since cant afford FI...maybe N2o
thats really nice!!
