Turbo Came in the mail... What's the deal?
Old Dec 16, 2002 | 06:39 PM
Johnyquest's Avatar
Default Turbo Came in the mail... What's the deal?
Guys, Matt here again; 95 civic EX. I have a question!~
I just came home from school and am seeing my turbo that came in the mail yesterday for the first time. I'm all ready to get my project on the road, but here's the deal. The exhaust flange lines up perfect with my manifold, but this turbo looks SMALL! I mean SMALL. What's the deal? The OUTLET has a 2" OD, and in inlet has a 2 1/8" inlet. The entire charger is less that 6" across. I'm going to try and figure out how to post a pic. INSIDE of the cold side outlet it is stamped with the number 42. It is a Garrett AiResearch turbo, and I can't find the A/R Anywhere. the only other useful / readable stamps are M27, and near the pressure outlet tap (for the wastegate) it is stamped with the number 68. It's not 63, I'm sure. It's 68. What does all this mean? Is this TINY for a turbo? I mean in all honesty, how can somthing less than 6" wide with a 1.5" outlet (2" OD) supply all the air my engine needs? Is this NOT a T3? It's supposed to be a t3 off a saab, early nineties. But seriously, it's microscopic. All responses appreciated!
Old Dec 16, 2002 | 06:41 PM
MiraiZ's Avatar
Default Re: Turbo Came in the mail... What's the deal? (Johnyquest)
pics please!
Old Dec 16, 2002 | 07:05 PM
Johnyquest's Avatar
Default Re: Turbo Came in the mail... What's the deal? (MiraiZ)
Pictures just taken, fresh. Less than 6".
http://www.geocities.com/johnyquest123/turboperf.jpg
http://www.geocities.com/johnyquest123/turbo1.jpg
http://www.geocities.com/johnyquest123/Turbo2.jpg
http://www.geocities.com/johnyquest123/turbo3.jpg
http://www.geocities.com/johnyquest123/turbo4.jpg
Old Dec 16, 2002 | 07:08 PM
khang77642's Avatar
sorry bro, cannot access pictures
Old Dec 16, 2002 | 07:09 PM
falcongsr's Avatar
What is this crap?
fix the pix?
i didnt think AiResearch turbos went on Saabs, but i am not sure.
Old Dec 16, 2002 | 07:16 PM
Honda4CX-T's Avatar
Now that's SMALL ...... But I'll bet you'll have a quick spool.
Here's what mine looks like compared next to DP & Mani: (I'll snap a better one to campare)
(Pic courtesy of Jackmoves)
Old Dec 16, 2002 | 07:23 PM
Johnyquest's Avatar
Default Re: Turbo Came in the mail... What's the deal? (Honda4CX-R)
yeah, yours is 2/3 the size of the manifold, according to my on screen measurements. Mine measures 1/2 manifold size. Is your's a t3 or a t3/t4? i'm not going to be able to respond after this post. I can't figure out how to make my user not be a 'trial user' and how to stop my 5 post a day limit...
Thanks for all your help guys... But seriously. Is this turbo even off a car? It looks like it's more appropriate for a tractor! You tell me.
Old Dec 16, 2002 | 07:28 PM
MiraiZ's Avatar
Kinda looks like a T3 or maybe a .48 AR t3/t4...any side pics? Also pics of the compresser IN and OUT would be good
Old Dec 16, 2002 | 08:00 PM
philo's Avatar
A T3 is a pretty small turbo, most people are used to seeing a T3/T4 with the much larger compressor housing.
I know Saab use low boost applications on most of there cars so a straight T3 is quite likely.
Old Dec 16, 2002 | 10:16 PM
Whooopasss's Avatar
Default Re: Turbo Came in the mail... What's the deal? (philo)
Yup.. that is a saab turbo alright, older gen.. comp 42 and turbine 48.. it's a garrete.. I have one right here but upgraded the compressor to a 60 ar (found it in a junkyard for $10.. the 42 ar are very small.. what engine are you going to use this??
Old Dec 17, 2002 | 03:05 AM
Honda4CX-T's Avatar
Mine is a Garrett T3/TO4E SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
[Modified by Honda4CX-R, 7:06 AM 12/17/2002]
Old Dec 17, 2002 | 06:38 AM
legendboy's Avatar
That is no Saab turbo. What saab turbo came with a 4 bolt turbine flange. None. A .68 or .69 turbine housing is an intresting find also. Doesn't look like any oem turbo to me...
Old Dec 17, 2002 | 08:44 AM
Johnyquest's Avatar
Default Re: Turbo Came in the mail... What's the deal? (legendboy)
Guys, the pics are all right here again for those of you who couldn't access them!
Http://www.geocities.com/johnyquest123/turbo.html
SMALL isn't it???? JEEZ!
Old Dec 17, 2002 | 08:48 AM
SiRkid's Avatar
i dont think he is saying that his t3/t4 is a saab turbo...LOL
Old Dec 17, 2002 | 10:09 AM
Pissoff's Avatar
looks like a saab(or a tbird) turbo to me
SMALLL T3
like 42/.48
[Modified by Usdm ED9, 2:10 PM 12/17/2002]
Old Dec 17, 2002 | 10:14 AM
accordfreak's Avatar
Default Re: Turbo Came in the mail... What's the deal? (Usdm ED9)
i think it looks like a volvo one
Old Dec 17, 2002 | 10:24 AM
Sonny's Avatar
It's a small turbo, but for your application, it will make decent power and allow you to upgrade later.
Saabs did come with a Garrett AirResearch turbo. I've pulled a few myself.
The specs on most Volvo and Saab turbos are:
.48 or .63 a/r turbine housing (.48 is the most common)
Stage 1 turbine wheel
Oil cooled center section (some are oil/water)
.42 a/r compressor housing
50 trim compressor wheel
I've seen a few 45 trim wheels, but they are almost all 50 trim wheels.
IMO, that is a great starter turbo for a D or non-VTEC B series engine. It will make decent power without blowing your engine to bits if you make a mistake. Sure, it's not gonna roast the tires in every gear, but I think it allows more room for error than say a T3/T04E or a T3/60-1.
IMO, too many people bite off more than they can chew when they start out. A T3/T04E is good for a well planned system and for someone who has experience
with a turbocharger system. For the first timer boosting on stock internals without engine management, a smaller T3 or a T25 is a good choice.
My 2 cents...
Sonny
[Modified by Sonny, 11:27 AM 12/17/2002]
Old Dec 17, 2002 | 11:35 AM
@irborne's Avatar
those factory turbo from saab, volvo, volks....are tiny, so my best bet your turbo is a real t3 w/ smaller trim size. i think it's more suitable for your sohc motor.
post a snap shot of the flange (where it mounts to the manifold).
philo's Avatar
Default Re: Turbo Came in the mail... What's the deal? (Sonny)
I agree with Sonny, a small unit is a good place to start, especially if you arent well versed with an EMS.
Old Dec 17, 2002 | 11:53 AM
Johnyquest's Avatar
I hear you guys, And it all sounds like good advice. I know I'm not going drag racing every day, and i figured this T3 would be good. I just didn't realize somthing THIS small could supply enough air for my engine. I mean, the aftermarket NA intake I have on my car is 3". The outlet on the turbo is 1.5". I'm just shocked that somthing this small can flow enough air to support (never mind boost) my engine. What size charge piping to I use? I mean, 2" sounds good to me considering the size of the turbo!
Old Dec 17, 2002 | 12:02 PM
johnisenglish's Avatar
Well put, I agree entirely. In fact, I'm using a 60trim T3 on my LS
There's nothing wrong with small turbo's
Old Dec 17, 2002 | 12:14 PM
M.A.R.C.'s Avatar
I'm pretty sure it's a .63 a/r turbine (the casting makes it look like .68) with a .42 a/r compressor. Those came stock on some volvo's. the .63 would be kinda big for a sohc civic IMO. My .48 turbine t3 spools up decently, not sure how much slower spool a .63 would be.
Old Dec 17, 2002 | 02:23 PM
Honda4CX-T's Avatar
Default Re: Turbo Came in the mail... What's the deal? (SiRkid)
I dont think he is saying that his t3/t4 is a saab turbo...LOL
Thank you (SiRkid), were's the confusion ?
Mine is a MaxRev Turbo Kit for "B" series compared to his .....
Old Dec 17, 2002 | 03:19 PM
Quiz's Avatar
Early model Saab turbo's
8v model- .48 A/R standard turbine wheel, .42 A/R 40 trim compressor wheel
16v model-.48 A/R standard turbine wheel, .42 A/R 45 or50 trim compressor wheel (depending on year)
If it had a .63 A/R turbine housing it's an aftermarket upgrade.
Looking at the pictures that turbo looks to be an 8v spec turbo but doesn't look like the average early model Saab turbo. That turbo has a water jacket. Saab 900 did not come with a water jacket. Don’t think the 9000 did either. Id say it’s defiantly a .48 a/r turbine standard wheel looking at it. To verify the compressor wheel. Measure the inducer diameter, looks to be about 1.5 inches (from you pic with the ruler) than divide it by 2.367 (major diameter of all t3's) then square it and multiply by 100. That will give you the trim number of the wheel. = 40 trim
Old Dec 17, 2002 | 03:33 PM
Quiz's Avatar
Default Re: Turbo Came in the mail... What's the deal? (Quiz)
Make sure your measuring the wheel blade to blade not the housing
