Engine shaking at the normal rpm
Old Dec 16, 2002 | 03:10 PM
sajm's Avatar
Default Engine shaking at the normal rpm
I bought this 90 accord lx 3 month ago. Everything has been good until last week. The car was good the first time I drove it to work in the morning (about 1 mile). Half an hour later, I started the car again, the engine suddenly became very shaky and the exhaust smells really bad. I quickly found out that one cylinder caused the problem (Put my hand on each spark plug cap, I can easily felt the knock on the third one from the left.). So I changed the 4 spark plugs. In fact the plug on the problematic cylinder is already very loose, I didn’t felt any resistance while try to loose it.
After the change of plugs, the engine seems to run smoothly at cold. But when it heats up and idle speed drops to normal 800 rpm, it starts to shake again. But this time I wouldn’t feel any difference among the four cylinders.
Really appreciate any suggestions.
Old Dec 16, 2002 | 04:35 PM
Desslok's Avatar
Default Re: Engine shaking at the normal rpm (sajm)
Sounds like it's time for a full tune up. Cap, rotor, plug wires, fuel filter, air filter, oil change, tranny fluid change. Better to do this now than be sorry later. When you buy a used car and don't know what maintenance has been done.
Old Dec 16, 2002 | 08:23 PM
Concorde's Avatar
Sell it and buy my car!
Old Dec 16, 2002 | 08:47 PM
cyrixvsp2's Avatar
Default Re: Engine shaking at the normal rpm (Concorde)
well, is it a vibration or a shake? there is a difference. My 91 ex has 164k miles on it and when it idles it vibrates a little, but no bad noises or anything, i'm sure that's just the way it is. It doesn't seem to be a problem because i've done everything to the car i can and it still is like that. Try just a tune up and if that doesn't help anything then it's probably just the standard vibration you are getting.
Old Dec 17, 2002 | 06:54 AM
sajm's Avatar
Default Re: Engine shaking at the normal rpm (cyrixvsp2)
Thanks for the reply. It is pretty bad shake. You can actually see it by looking at the engine. Though the car is old, it has only 90k miles on it. I bought from a friend who had the car for years. I drove it only 4 miles a day and 5 days a week, won't bother with any small vibration at all.
Drop the car at a garage today. Will post the result if they fix it.
I
Old Dec 17, 2002 | 08:09 AM
KoKreation's Avatar
does it shake hard while while you are inside the car...check you motor mounts.
Old Dec 17, 2002 | 05:14 PM
BoostedH23a1's Avatar
Default Re: Engine shaking at the normal rpm (PiNg~PiNg)
are u getting fuel to that cylinder? could be a bad injector.
Old Dec 18, 2002 | 07:10 AM
sajm's Avatar
Default Re: Engine shaking at the normal rpm (BoostedH23a1)
Problem fixed. It was the faulty ignition wiring that caused the engine to miss fire, at least that what I was told by mechanics. This morning, the car is happy running again.
Thank you all.
Brown328
Apr 4, 2013 10:27 PM
badboiz530
Apr 25, 2010 03:32 PM
AlphaKennyWun
Feb 2, 2008 02:16 PM
motormanSR
Mar 15, 2005 02:46 PM
Si4WS
Jul 29, 2002 10:03 PM
