my nitrous is pulsing, whats up?
Old Dec 16, 2002 | 12:18 PM
tek_civic's Avatar
Default my nitrous is pulsing, whats up?
so i just installed a NX EFI "import" kit on my d16z6 civic and when i get on the nitrous at WOT the power seems to pulse and not be constant, whats up with this? i think i heard somewhere that its because i don't have a bottle warmer yet, is that true? thanks
Old Dec 16, 2002 | 12:22 PM
PM-Performance's Avatar
Default Re: my nitrous is pulsing, whats up? (tek_civic)
im betting on bottle pressure or lack there of .
heat the bottle up in the bath tub or something and get the temp up and try it then ,
deff downb the line get a bottle warmer,
whats your pressure at ?
if you want to run good , get a heater, pressure gauge and purge, that way you can at make it work and know how much pressure you got at all times.
Old Dec 16, 2002 | 12:23 PM
boosted3g's Avatar
It could be. When i ran nitrous back in the day it was usually a fuel problem. Most companies run toward the rich side and that will cause a stumbling on and off again feeling. I would see how your a/f mixture is but it sounds like your too rich.
Old Dec 16, 2002 | 12:40 PM
Default Re: my nitrous is pulsing, whats up? (boosted3g)
well i ran rich as hell a few times and never had that prob, it felt strong as hell and no pulsing , but i noticed mt ets were higher than they should be and the traps were low
put in smaklker jets and viola a whole diff car
but i dont think its fuel.
Old Dec 16, 2002 | 12:42 PM
tek_civic's Avatar
thanks for the help, i am getting an a/f gague soon and i already have a pressure gague but i have no way to mount it to the bottle. They forgot/didn't want to send me the piece necessary to put the gague on the bottle. i will soon have the right piece so that will be solved too.
EDIT:
i am going to check my plugs today and see what they tell me, since they are new plugs(same day as nitrous) they should be a pretty good look into my engine.
[Modified by tek_civic, 2:48 PM 12/16/2002]
Old Dec 16, 2002 | 02:00 PM
they wont , if they dont have enough miles on em it wont give you an accurate reading .
Old Dec 16, 2002 | 03:36 PM
tek_civic's Avatar
Default Re: my nitrous is pulsing, whats up? (itr206)
oh ok thanks for that, i might have checked them and thought it was all fine when i really couldn't tell.
bossm
Dec 22, 2008 08:16 AM
d15.hatch
Apr 4, 2006 03:29 PM
Layziebtnh055
Aug 8, 2005 12:47 PM
ZexyAccord
Nov 13, 2004 08:47 PM
tegasaurus
Jan 11, 2003 02:31 AM
