Axles? CRX/b18
Unaltered 1990-1993 Integra axles are NOT a perfect fit. First of all, the dust seals on the knuckles need to be removed. And then there is the possibility that the passenger side axle will be too long. If you just want a quick and easy axle to use, you can try a 1990-1993 Integra axle. Or you can use the RIGHT axles. And that would be either JDM SIR axles or their home made version (1990-1993 Integra inners with 1986-1989 Integra outers and shafts). A 1990-1993 Integra intermediate shaft should be used regardless.
2x0
16
Sep 21, 2017 05:13 AM
4inspeed
10
Feb 28, 2004 06:34 PM
