DSM 450's
Got a few questions about DSM 450's. First do they run small screens like honda does and also the bottoms where it goes in to the runners, where do I get those gaskets? Can I get them from DSM or do I have to modify my civic ones?
That should be about it, already have the injector resistor box, B&M FPR, V-AFC this would be going into a B18.
TIA
TIA
I have had 4 sets of dsm 450's and none have had screens..
If you dont feel like making your own seals, you can buy them directly from http://www.zdyne.com @ a ripoff price I'm sure...
To make your own, get a high speed dremel/die grinder with some type of bit... (I like carbid bits) and just start cutting away the center of the stock O-ring seal. Do it so the injector fits nice and snug, then try a test fit. Should be just fine.
Jeff
Jeff
Thats what I was thinking had to use the trusty dremel hehehehehe. Didn't see where the screen would go unless its internal. On 3 of them it had 3 small bars at the top looking into the injectors they kinda went inwards, but one didn't have it but I was told that was no problem and wouldn't affect anything. Correct or incorrect??
bacnoonoi
Mar 25, 2007 07:47 PM
