will si distributor fit on DX?
Old Dec 16, 2002 | 07:58 AM
Agent Daimon's Avatar
Default will si distributor fit on DX?
just what the topic says..some guy is trying to sell me a distributor off an 91 si for 50 bucks but i have an 88 dx and i am NOT trying to do an mpfi swap.....and he said it will work...
si = 7pin
dx 5 pin
so no it will not work?
[Modified by Agent Daimon, 5:11 PM 12/16/2002]
Old Dec 16, 2002 | 08:05 AM
Vinceg99's Avatar
Default Re: will si distributor fit on DX? (Agent Daimon)
Yeah it will work thats one of the things you need when your doing a DPFI to MPFI swap but the Si has a Cylinder Postion sensor in it which the DX doesnt have at all. As for using it with just a stock DX I dont know? Maybe not wire up the sensor? I do know that it fits though....
Old Dec 16, 2002 | 08:13 AM
Default Re: will si distributor fit on DX? (Vinceg99)
thanks for the info but..im not doing the mpfi swap...
Old Dec 16, 2002 | 09:20 AM
Malgerus's Avatar
99.9 percent sure you can't use the Si distributor for DPFI.
Old Dec 16, 2002 | 09:22 AM
zCivic's Avatar
Default Re: will si distributor fit on DX? (Mr. S)
You can use the diz. You need to pop on your old square plug for the 5 pins and just leave the blue/yellow and blue/green unhooked. I have a xtra DX diz if your interested though....
Old Dec 16, 2002 | 10:14 AM
4drEF's Avatar
Keyboard Humorist
Default Re: will si distributor fit on DX? (zCivic)
Correct. Using the DX distributor in an SI will only fire 2 of the 4 injectors. Using the Si in the DX will send 2 extra signals, but don't use them... you still get the 2 correct signals you need for the 2 injectors that the DX has.
Plug swap required... Si has 2 extra wires so don't use them.
Old Dec 16, 2002 | 05:42 PM
ok i didnt buy the si dizzy..i guess my car will still be out of commission for awhile until i find a dx distributor for cheap. anyone have one laying around in good condiition.? So Cal please...
Old Dec 16, 2002 | 06:08 PM
horoke14's Avatar
i have a dx distributor for sale and i am needing an si disdtributor. if you buy the si one i will trade you my dx one for it. email me horoke14@yahoo.ie
Old Dec 16, 2002 | 10:28 PM
Vinceg99's Avatar
zCivic has one he posted it above
Old Dec 17, 2002 | 03:42 AM
zCivic's Avatar
Accually I have the whole block....Along with a shat load of xtras. IM me if you need that Diz Its in TN and will hook you up on price and s&h.
92coupe
12
Nov 5, 2010 08:30 PM
classciv
Apr 2, 2006 03:30 PM
Big Bang
14
Aug 22, 2003 06:18 AM
turbohf
13
Feb 20, 2003 04:38 PM
CimorelliCRX
Apr 3, 2002 12:18 AM
