h22 pistons in f22?
Old Dec 15, 2002 | 10:36 PM
ratherbewalking's Avatar
Default h22 pistons in f22?
just wondering if this can happen.
Old Dec 16, 2002 | 04:50 AM
jweller's Avatar
Default Re: h22 pistons in f22? (ratherbewalking)
H22 has a bigger bore than a f22. you'd have to get the block bored out, as well as have the combustion chambers matched on the head. You ~may~ have headgasket sealing issues as well. If you were thinking H22 slugs were cheaper and thats why you wanted to use them, then forget it. the block and head work raises the price a good bit.
edit: wristpin location might be different as well...not sure.
[Modified by jweller, 8:51 AM 12/16/2002]
Old Dec 16, 2002 | 05:25 AM
SOHCArchangel's Avatar
Default Re: h22 pistons in f22? (jweller)
well since the h22 rods are a wee bit longer than the accords i have the same quizzical befuddlement of wristpin location
Old Dec 16, 2002 | 10:03 AM
thanks
Old Dec 16, 2002 | 11:52 AM
JPX's Avatar
JPX
F22/h23 rods are longer than the h22
I would sleve the block for h23(87mm bore) then use H22 pisons
Best combo...
Old Dec 16, 2002 | 12:29 PM
dennis's Avatar
Default Re: h22 pistons in f22? (JPX)
I'm pretty sure it's the other way around - h22's being longer by about 1.5mm
civic_ash
May 1, 2015 10:52 PM
h22aCb7
Mar 5, 2007 02:27 PM
opey045
May 25, 2004 06:51 AM
