installed reverse indiglo gaues and now my needles are messed up
Oh yeah I forgot I can edit my own title! Yay!
just like the title says, i installed reverse indiglo gauges for my '99 Accord. I removed the entire housing and then took off the needles, placed on the reverse indglo and then replaced the needles. Then i put them back into the car, but when i started my car, the "HOT/COLD" needle went all the way up to H and my speedometer needle hardly moved when i floored the engine. ANy suggestions on what to do? Thanks
is cause the indiglo gauge isnts flat on the guage cluster n its holding it down casue its stuck i think but if u can check n if its flat on the surface or not
you will probably need a new cluster
Thats your problem right there....you don't take off the needles
or have it recalibrated at the dealer or something. you're screwed!!!
damn. well i'm taking it into the dealer this morning, and i hope they can recalibrate them. I don't think that the gauges aren't flat because my RPM needle is working fine. I just think the other two are a little off. what do you guys think?
