help windex on gauges
Old Jul 13, 2008 | 07:06 PM
Defiant_dc's Avatar
Default help windex on gauges
As I was cleaning my car minding my own busines I wasn't thinking and i sprayed windex on my gauge cluster. And now half of it is all foggy ... Could anyone tell me if theres a way to fix this problem?
Old Jul 13, 2008 | 07:22 PM
Tip14's Avatar
Did you try putting a dab of armor all on it? It might get rid of the fog for a while. Its worth a try lol
Old Jul 13, 2008 | 08:03 PM
BTT's Avatar
BTT
Default Re: help windex on gauges (Defiant_dc)
Its fogged up behind the glass (in between the glass and gauges?)
Thats difficult, how long has it been like that? All i can think of is taking your gauge cluster out and removing the front glass if possible, then wiping it down or letting it air out.
And if you can you might want to spray some anti-fog or something in there
Old Jul 13, 2008 | 10:18 PM
Mfoehrkolb's Avatar
taking out your cluster is EZ. its literally 5 screws.
Once you take it out you will see tabs holding the clear part on. You push int he tabs and pry apart gently. It actually helps to have 2 people. 1 to pry and 1 to hold and push tabs.
Then you clean, put back together and install.
that ez....
Old Jul 14, 2008 | 08:13 AM
Defiant_dc's Avatar
ko ty.. But the armor all thing worked ... didn't think it would but thanks lots
Old Jul 14, 2008 | 08:42 AM
Mfoehrkolb's Avatar
if the armor all thing worked then it wasn't on the inside of your cluster.
Jackson024
Nov 5, 2005 10:48 PM
ECKOTYPER
Apr 25, 2004 10:25 AM
mattymatt
May 6, 2002 02:07 PM
ITR_MD
May 8, 2001 05:05 AM
