help me troubleshoot this problem please...
Old Dec 15, 2002 | 09:12 PM
del_parker's Avatar
Default i need help!
alright, friday afternoon my car started making a grinding sound under acceleration while i was on my way to atlanta from statesboro, ga...and there was a little bit of slippage it seemed. the night before i was playing around in a parking lot just trying to break the rear end loose, but that's the only thing i can think of that i've done in the past few weeks(been busy with finals...). the cv joints aren't making any noises/grinds when i turn, and the axles seem like there all the way in the transmission. does anyone know what might possibly be going wrong?
i'm suspecting maybe my differential might be going out, but i'm unsure. i replaced the transmission(h23), clutch(act xtss), flywheel(cm 8 lbs) and driverside cv axle(slight mishap remounting the original...involving some broken bearings) in august...following that i've replaced the driver side 4 more times...DO NOT BUY ADVANCED AUTO PARTS' cv axles...they're pure ****, stick the original or get some performance axles.
anyway, suggestions are greatly appreciated.
thanks,
Del
[Modified by del_parker, 11:55 AM 12/16/2002]
Old Dec 16, 2002 | 07:36 PM
del_parker's Avatar
Default Re: i need help! (del_parker)
ttt
Old Dec 16, 2002 | 07:39 PM
ViruX's Avatar
does it make the noise in all gears?
-Vi
Old Dec 16, 2002 | 08:03 PM
del_parker's Avatar
Default Re: i need help! (ViruX)
yep... and the noise comes and goes. it doesn't always happen. loose axle?
Old Dec 16, 2002 | 08:12 PM
ViruX's Avatar
when was the last time you changed your MTF? could be an axle. it dosent make any noises at idle, or being revved at idle?
-Vi
Old Dec 16, 2002 | 08:15 PM
del_parker's Avatar
fluid was changed 3.5 months ago...along with the transmission. nothing at idle.
Old Dec 16, 2002 | 08:22 PM
ViruX's Avatar
direction its coming from.....front driver.....front pass?
-Vi
Old Dec 16, 2002 | 09:47 PM
del_parker's Avatar
feels like the center, but occasionaly there's some drive side bias...at least i think.
Old Dec 17, 2002 | 12:18 AM
nsxtarga's Avatar
I think i have the same problem with my 2000 Lude... i happens when i stop then accelerate...it just make a weird 'er' sound...dont know where is from man..just **** me off...dont happen on all the other gears
Does any one know what is wrong?
Old Dec 19, 2002 | 09:38 AM
del_parker's Avatar
UPDATE:
i removed the driver side cv axle and the grinding noise went away. i reinstalled it, and it came back. it looks like the cv axle might be slightly loose from the intermediary shaft, could that be making the noise? could i possibly just need a new set ring?
Old Dec 19, 2002 | 10:37 AM
Sephro's Avatar
first off you should be replacing the set ring every time the axle is taken off. If the noise is comming from that area I might check the bearings in the half shaft. Because you said the CV Axle is new correct? It could just be bad bearings. Cheap to fix. Pain to check/change.
SpoonyDC5
Feb 11, 2013 02:20 PM
lilshady6796
Nov 29, 2008 01:34 PM
meangreenEG
45
Jul 6, 2007 08:16 AM
dc4teg95
May 15, 2007 10:24 PM
scrap1ngsr
May 19, 2004 10:04 PM
