axle question?
Old Dec 15, 2002 | 02:56 PM
91hondacrx's Avatar
Default axle question?
The axles from an si will fit into a dx tranny right, or vise versa? Just making sure, i was goin to do the swap from dx to si and now i just think i am goin to rebuild the dx. Just for the reason of lasting, not performance.
Thanks,
Matt
Old Dec 15, 2002 | 03:48 PM
the DR.'s Avatar
Default Re: axle question? (91hondacrx)
theyre the same
Old Dec 15, 2002 | 05:11 PM
USDM 4G VTEC's Avatar
yes the DX axles willl work on a Si tranny..
the STD axles end that goes into the hub are smaller than the Si ones and DX ones .... DX and SI have same hubs
someone correcet me if i am wrong...
[Modified by JDM EF9, 9:37 PM 12/15/2002]
Old Dec 15, 2002 | 05:26 PM
FourthGenHatch's Avatar
Default Re: axle question? (JDM EF9)
No STD axels had less splines and we a lot smaller than the Si or DX ones which I think are exactly the same.
[Modified by FourthGenHatch, 2:27 AM 12/16/2002]
Old Dec 15, 2002 | 06:00 PM
Aron Parsons's Avatar
Default Re: axle question? (FourthGenHatch)
yes, they are the same.
Old Dec 15, 2002 | 06:01 PM
91hondacrx's Avatar
What about si axels in a dx tranny?? that is what i wasn't sure of. How about pistons and rods, what could make a healthy amount of power but be safe without raising compression so much. I know about the teg pistons you can put in and raise compression.
Matt
Old Dec 15, 2002 | 06:14 PM
90civichb's Avatar
What axles will fit a std? Both of my front axles are completely shot, need some replacements at a good price...
Old Dec 15, 2002 | 07:58 PM
altoid's Avatar
Default Re: axle question? (90civichb)
get some stage 5s at driveshaftshop.com...they should last you a life time
Zawacki
12
Mar 8, 2008 08:44 PM
terminaloverlowd
Jun 17, 2004 02:23 PM
shortyz
Aug 13, 2002 11:48 AM
zcivicz
30
Apr 15, 2002 02:29 PM
charjacq
Apr 11, 2002 04:17 PM
