Civic Type-R Piston Question
Old Dec 15, 2002 | 01:03 AM
OBD1 Kenobi's Avatar
Default Civic Type-R Piston Question
I am going to be putting CTR pistons in my B16A. For the wrist pins and rings, are the USDM/CDM GS-R, ITR, Si(R) ones the same parts or is it a CTR exclusive part?
Old Dec 15, 2002 | 08:15 AM
b19coupe's Avatar
Default Re: Civic Type-R Piston Question (OBD1 Kenobi)
GSR and ITR piston rings are the same as CTR's. The wrist pins should come with the pistons, but GSR/ITR pins are the same.
Old Dec 15, 2002 | 01:51 PM
I have had many people who were sure this was the case with the rings but were not 100% positive. Are you sure? I didn't think the wrist pins came with the pistons though.
Old Dec 15, 2002 | 02:14 PM
b19coupe's Avatar
I have purchased two sets of ITR pistons from the dealer, they came with wristpins.
I used my ITR pistons rings on a set of CTR pistons that I put in an LS/VTEC-compression was perfect, no oil consumption. I have seen numerous dealer bought pistons, all come with wristpins.
[Modified by b19coupe, 11:15 PM 12/15/2002]
Old Dec 15, 2002 | 11:43 PM
Default Re: Civic Type-R Piston Question (b19coupe)
That's great to hear. I'll be ordering my CTR pistons with the wrist pins and then get the rings from the dealer. I am going to check the SiR part number to see if it is the same as the GS-R/ITR as it would cost less.
SiR rings are the same!
[Modified by OBD1 Kenobi, 3:19 PM 12/16/2002]
racebum
Sep 27, 2008 05:15 PM
neeks
Mar 7, 2005 11:25 AM
wm5holla
Feb 7, 2003 06:53 AM
JD_B18CDX
Jul 3, 2002 07:51 AM
