Hondata
Old Dec 15, 2002 | 12:01 AM
Goldfingiz's Avatar
Default Hondata
Hey guys, which would be best for a B16 running 12psi in a 92 Integra? Would the S100 be good enough?
Thanks,
Goldfingiz
Old Dec 15, 2002 | 09:20 AM
Goldfingiz's Avatar
Default Re: Hondata (Goldfingiz)
Hey guys, will a Hondata Stage 2 (not 2b) be good? I found one at a great price, and I'm on a budget.
Thanks,
Goldfingiz
Old Dec 15, 2002 | 09:30 AM
Goldfingiz's Avatar
How about a s200 without boost? How necessary is this feature?
Thanks,
Goldfingiz
Old Dec 15, 2002 | 12:08 PM
Kataku2K3's Avatar
I would get it will the boost feature... A 2B setup would work perfect for you... My friend's GSR turbo EK runs 2B on 13lbs... It makes 355whp... Seems to be working pretty good... Good Luck
[Modified by JDMspecEG6, 1:09 PM 12/15/2002]
Old Dec 15, 2002 | 02:11 PM
C-speed's Avatar
Default Re: Hondata (JDMspecEG6)
There is no reason to get the stage 2-4's anymore. They are being replaced by the s100 and s200 systems.
If you are boosted, then you MUST get the boost upgrade, otherwise it will not work correctly.
If you never plan on wanting to tune the system yourself, then the s100 with boost is fine. However, if do plan on upgrading for datalogging, full-throttle shift, launch control or being able to tune yourself, then you MUST get the s200 system with boost.
check here:
http://www.c-speedracing.com/onlinestore/hondata.php
hth
Old Dec 15, 2002 | 08:15 PM
Goldfingiz's Avatar
Default Re: Hondata (G3-TEG)
Thanks guys! What will I need if I get the S200+Boost upgrade. Larger injectors and a 3 bar map sensor? I had no idea a 3 bar map sensor costs $900! WTF! I don't think this is going to work out =\
Goldfingiz
Old Dec 25, 2002 | 12:36 AM
RAWB's Avatar
Goldfingiz
I think you saw an extra "0" there, 3 Bars run about $90.
Old Dec 25, 2002 | 12:43 AM
smallttocs's Avatar
Default Re: Hondata (integracon)
just quick fyi, you can press the "edit" button to change your post incase you think of something new or something you'd like to change instead of posting numerous posts. the button is right next to where the "reply" button is. it only shows up on the messages you post.
95dxsir2
Aug 25, 2007 02:37 PM
95dxsir2
Aug 25, 2007 02:33 PM
