Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
brake setup taylored for course-see inside
Old Dec 14, 2002 | 08:07 PM
Night_Minx
Guest
Posts: n/a
Default brake setup taylored for course-see inside
The circuit in refernce to is the outer high speed ring (denoted in RED)
typical speed is about 60mph. Turns 8 and 9 are banked, and full out throttle, exiting at about 90mph, into the 2 gear downshift chicane. Thats about the heaviest braking on the course, go from about 95 to 45. I need a streetable brake setup, that suits this course as well. I was thinking stock rotors, with some type of pad, hawk, carbotech, etc etc not sure. And stainless steel lines, with ATE Super Blue brake fluid. any comments, suggestions, etc.. would be appreciated
right now, i have brembo crossdrilled (warped) and stillen metal matrix pads, with fresh OEM honda fluid.
Old Dec 14, 2002 | 08:19 PM
.RJ's Avatar
.RJ
Default Re: brake setup taylored for course-see inside (Night_Minx)
roebling road?
stock rotors, ate/ford hd/cobalt fluid, ferodo/carbotech xp pads - call andie @ cobalt friction ( http://www.cobaltfriction.com ) and he'll hook you up
Old Dec 14, 2002 | 08:27 PM
Night_Minx
Guest
Posts: n/a
Default Re: brake setup taylored for course-see inside (.RJ)
roebling road?
Actually, this is the Minnesota State Highway Patrol testing and training grounds, located in St. Cloud, MN.
Old Dec 14, 2002 | 08:36 PM
.RJ's Avatar
.RJ
looks similar...
Old Dec 14, 2002 | 08:54 PM
JeffS's Avatar
my 2 cents...
Carbotech Panter+ in the front, stock rotors, decent fluid and go drive.
Old Dec 14, 2002 | 09:03 PM
johng's Avatar
Look at the scale - it's a pretty small course. You'd probably be fine with factory everything, but my $.02 on pads is to go with Hawk HP-Plus, Porterfield R-4S, or something by Carbotech or Cobalt. Check http://www.nipponpower.com for Hawk pads.
Old Dec 15, 2002 | 11:06 AM
Madracer1's Avatar
Default Re: brake setup taylored for course-see inside (johng)
Hawk HP+ wont do it.....How do I know? I smoked mine totally last time I was out there. Also dont forget turn 1 and 3 require some heavy braking as well. Keep also into consideration that my car is supercharged and the speeds are relatively higher than stock(considering you own N/A Honda). My plan for next year was Hawk Blues and Autozone rotors with Mobil Synt Fluid.
HTH
Rado
Old Dec 15, 2002 | 04:23 PM
Night_Minx
Guest
Posts: n/a
Default Re: brake setup taylored for course-see inside (Madracer1)
i have boosted honda now. Did you have that red GSr w/cage?
Old Dec 15, 2002 | 04:26 PM
.RJ's Avatar
.RJ
make sure your pads/fluid are fresh for the track if you're boosting.... thats alot of extra speed to scrub off
Old Dec 16, 2002 | 05:25 AM
Tstorm's Avatar
I use the stock rotors with Axxis Ultimate pads and I have not had any problems with rotors. What's your best lap time ?
ekim952522000
Jan 4, 2006 08:22 PM
clement_h
May 15, 2003 12:39 PM
TRE_
12
Aug 11, 2002 09:53 AM
turbo Si
Aug 8, 2002 07:30 PM
Yellow Dragon
Jun 28, 2001 10:12 AM
