Brake Upgrade Suggestions
Old Aug 5, 2002 | 01:48 PM
turbo Si's Avatar
Default Brake Upgrade Suggestions
Ok here is my delima. I have a '99 Si. I need a more responsive brake setup although I can't go bigger than stock due to my 13 inch Bogarts that I use at the track. Someone told me that Willwood might make a two piston caliper that will be equivilent in size to the stock caliper, although that is not for sure. I don't want to spend thousand's of dollars on a setup. I am sure people on this forum have gone through this problem so your information will be greatly appreciated.
Thank You, David!
Old Aug 5, 2002 | 08:13 PM
sparkz's Avatar
Default Re: Brake Upgrade Suggestions (turbo Si)
spend money on new brake rotors (non cross drilled/slotted kind) and really nice brake pads like the Hawk HP+. world of a difference over stock
Old Aug 6, 2002 | 09:00 AM
martini's Avatar
Default Re: Brake Upgrade Suggestions (sparkz)
agreed. get some brembo blank rotors, and some HP+ pads, and maybe some steel braided lines, and flush out all your fluid, put in some good fluid, and call it a day.
Old Aug 7, 2002 | 07:35 AM
turbo Si's Avatar
Default Re: Brake Upgrade Suggestions (martini)
Good fluid....such as? I just use any DOT 3 or 4 brake fluid I find. I always thought brake fluid was brake fluid. What brand or type is everyone else using?
Old Aug 8, 2002 | 07:30 PM
stevel's Avatar
ATE Super blue is good. Might not be able to find it at any auto parts store. Try a specialty performance shop in your area or somewhere on the net.
Check out http://www.collettimotorsports.com, they have awesome prices on packages.
Jettplane
14
Mar 11, 2013 05:35 AM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
Mag00n
Jul 21, 2005 07:08 PM
MALVARO
17
Apr 15, 2004 02:33 PM
TRE_
12
Aug 11, 2002 09:53 AM
