Ok,Can you guys clarify this for me (involving going obd2-1)
Old Dec 14, 2002 | 12:35 PM
slwazgsr's Avatar
Default Ok,Can you guys clarify this for me (involving going obd2-1)
Ok I am currently OBD2 1996 Greddy Turboed GSR
Fuel Set-up is the 450's and SMC
Now I just bought a skunk2 jumper and a stock p28
Do i just plug and play and I should be OK with that? I understand that the p28 won't open my secondary runners and I understand that the SOHC has a different fuel settings and rev limit, BUT will my car run ok with just the p28 and jumper plugged in? TIA
Old Dec 14, 2002 | 12:39 PM
DC2R714's Avatar
Default Re: Ok,Can you guys clarify this for me (slwazgsr)
You need to chip the P28 with a DOHC program. I used a turbo Hasport program that has worked well for me. Cost around $150 I believe to get chipped by them. Helped make power across the board.
Old Dec 14, 2002 | 10:03 PM
slwazgsr's Avatar
Default Re: Ok,Can you guys clarify this for me (DC2R714)
so I can't just plug it in and go?
Old Dec 14, 2002 | 10:13 PM
SOUNDEFFECTS's Avatar
yes, you should be able to for the time being. It will run and what not, maybe even idle good but it won't run worth **** if you try to get on it. Switch to a SKunk manifold because the p28 doesn't have the ability at ALL to control the secondary runners.
Old Dec 14, 2002 | 10:17 PM
wickedxboi's Avatar
Default Re: Ok,Can you guys clarify this for me (SOUNDEFFECTS)
u may need a resistor box for the injectors
Old Dec 14, 2002 | 10:38 PM
slwazgsr's Avatar
Default Re: Ok,Can you guys clarify this for me (wickedxboi)
oh, i'm already running the 450's in the car with the injectors, thanks though
Old Dec 15, 2002 | 02:06 PM
slwazgsr's Avatar
ttt
Old Dec 15, 2002 | 05:15 PM
vtec.dc2's Avatar
as mentioned above, as long as you have the correct harness, its plug-n-play, i've seen dohc cars run on sohc ecu's, but not pushing the hp they can. i woulnd't do it on my car.
[Modified by vtec.dc2, 9:16 PM 12/15/2002]
dc4drewH
Jun 6, 2005 08:07 AM
Lee_Delso
11
Dec 13, 2004 07:41 AM
Vic Nyce
Apr 3, 2003 03:42 PM
1 speedstar
Jan 24, 2003 06:32 AM
