Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile?
Old Dec 14, 2002 | 12:11 PM
GQ 05YellowEVO8's Avatar
Default Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile?
I was wondering if I should heat wrap my Toda Header? How much does the tape sell for and where can I get them cheap?
After I remove the heat wrap would my header look crappy?
Would it cause the Header to crack due to higher temps being insulated?
Old Dec 14, 2002 | 01:08 PM
H-PIMP's Avatar
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (TODA-POWERED 95 GSR)
CAI is no prob, header will crack eventually regardless of quality.
Old Dec 14, 2002 | 01:37 PM
azn98R's Avatar
Man you'll cover up the bling
Old Dec 14, 2002 | 02:45 PM
MK Ultra's Avatar
I wouldn't do either.
Insulating the intake is pointless because the air is moving through it too quickly to have a chance to absorb much heat.
Old Dec 14, 2002 | 03:20 PM
Bbasso's Avatar
Jet coat the header and be done.
Old Dec 14, 2002 | 06:46 PM
tnord's Avatar
iirc......once you put the tape on there, it pretty much doesn't come off. of course, that could be completely dependent on what brand you get.
Old Dec 14, 2002 | 06:54 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (tnord)
no toda bling?
Old Dec 14, 2002 | 08:23 PM
DarthLuder's Avatar
New User
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (Bbasso)
Old Dec 15, 2002 | 07:19 AM
Haunt's Avatar
Old Dec 15, 2002 | 07:40 AM
Dropspeed's Avatar
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (MK Ultra)
Ever tested it? For dragracers is helps prevent heat soak fron inside the engine bay while waiting to make the next pass. On the street it is not really needed.
Mattj
Old Dec 15, 2002 | 08:07 AM
Tommy_Gunns's Avatar
If that was true, intercoolers would not work.
Stock rubber intake tube rocks
Old Dec 15, 2002 | 08:43 AM
skafia's Avatar
25 Year Member
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (H-PIMP)
Would the JDM 4-1 also eventually crack?
Old Dec 15, 2002 | 09:15 AM
MK Ultra's Avatar
Default Re: Should I heat wrap my Toda Header and AEM ITR CAI? worthwhile? (Tommy_Gunns)
Intercoolers are intended to cool air that has been heated from being compressed by some form of forced induction, not to keep heat from transferring to air travelling through an intake.
No, I haven't tested the heat wrap under drag racing conditions (which would be about the only way to measure a difference in performance for that particular mod). I am not an avid drag racer and I must admit that I was thinking purely in terms of street driving.
Old Dec 15, 2002 | 09:42 AM
Yes and how do you suppose that air gets cooled in an intercooler? Through conduction and convection heat transfer.
Same thing applies to your CAI. I think wrapping your CAI is worthwhile especially if you have a tubular header.
Old Dec 15, 2002 | 10:24 AM
MK Ultra's Avatar
Yeah, but an intercooler has a whole lot more surface area than an intake t00b. And it's mounted in a place where there is constant airflow forced through it, not where the air is more or less stagnant.
Old Dec 15, 2002 | 10:36 AM
thanks for all the replies guys!
Old Dec 15, 2002 | 11:48 AM
Exactly...so as your CAI gets hotter, guess what cools it...the moving air inside the tube.
Old Dec 15, 2002 | 10:56 PM
MK Ultra's Avatar
So if the air flowing through the t00b is sufficient to keep it cool it stands to reason that insulating it would only serve to trap heat longer.
blackk20dc5
Jan 26, 2009 06:17 AM
tealchief
Jan 8, 2009 01:25 PM
Del Soouulll
15
Apr 11, 2007 10:23 PM
OMG WTF
Feb 5, 2006 11:52 AM
totsie7944
29
Jan 4, 2006 02:50 AM
