9:1 JE pistons in an SI gives what CR is a GSR?
Old Dec 14, 2002 | 10:28 AM
bcause's Avatar
Banned
Default 9:1 JE pistons in an SI gives what CR is a GSR?
I have 4x 9:1 JE pistons for SI's. I would like to know what CR would it give me if I put those pistons in a gsr engine?
did a search but no luck
karl
Old Dec 14, 2002 | 10:30 AM
Evil EG's Avatar
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (bcause)
c-speedracing.com has a calulator for that. Try plugging in all the correct specs and it will tell you.
Old Dec 14, 2002 | 11:53 AM
bcause's Avatar
Banned
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (BVM)
thanks but I don't know all the specs of the pistons..they are JE 9:1 CR 20 over for SI's and just want to know what CR they will give in the gsr engine?
[Modified by bcause, 9:29 PM 12/14/2002]
Old Dec 14, 2002 | 12:40 PM
SiRkid's Avatar
i think it would be slightly higher....(or im mixing things up ni my brain ) and its lower sorry, that wasnt much help
Old Dec 14, 2002 | 12:56 PM
b18CT's Avatar
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (SiRkid)
9.2-9.3 in a gsr
Old Dec 14, 2002 | 01:40 PM
boostaholic's Avatar
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (REVTurbo)
~9.1 in a b16 w/ b16 head is going to yield around ~9.8/9.9 in a GSR w/GSR head.
Old Dec 14, 2002 | 01:54 PM
bcause's Avatar
Banned
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (boostaholic)
thanks guys..
if anyone has exact numbers....
[Modified by bcause, 10:56 PM 12/14/2002]
Old Dec 14, 2002 | 01:59 PM
sweet's Avatar
a .20 over B16A piston in a B18C1 (using the GSR rods, block and head) yields 11.4:1 C/R. so i would think that a .20 over piston that yields 9.1 in a B16A motor equals 10.3:1 C/R in a B18C1 motor, a difference of 1.1:1 C/R.
but of course there may be something i'm missing. having the piston displacement specs makes it easier to calculate.
Old Dec 14, 2002 | 03:59 PM
avividmemory's Avatar
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (sweet)
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Dec 14, 2002 | 04:13 PM
philo's Avatar
I asked JE about this when i bought mine, they said my 9:1 B17 pistons would yield 8.5:1 on a B16 head.
So I imagine it you be 9.5:1 going the other way.
Old Dec 14, 2002 | 04:47 PM
bcause's Avatar
Banned
Default Re: 9:1 JE pistons in an SI gives what CR is a GSR? (philo)
realy appreciate guys..
spoolinLS: I know but I didn't have all the info needed to calculate..
Old Dec 14, 2002 | 07:57 PM
b18CT's Avatar
9:2 100% sure
b18CT's Avatar
sorry 9.2:1
Old Dec 14, 2002 | 08:13 PM
9:2 100% sure
I think you're thinking of just the difference in a b16 and a gsr head which is roughly .2 points different compression. Using the calculator on c-speed racing's site, you need a -1.0cc dished piston dome volume to yield a 9.0:1 c/r in a b16 w/ stock 3 layer headgasket and b16 head and a .020" overbore. Use those same specs, but with a GSR block and head and you get 10.0:1 c/r.
[Modified by boostaholic, 5:15 AM 12/15/2002]
bustdgst
Jul 26, 2007 12:28 PM
jdm_vtec
Feb 28, 2007 09:43 AM
Boostage
Apr 24, 2005 11:31 AM
Blown90hatcH
Aug 3, 2001 10:54 AM
