ZC in 4wd Civic wagon???
Old Dec 14, 2002 | 06:16 AM
blacksheep's Avatar
Default ZC in 4wd Civic wagon???
This is a question I've had in the back of my head for a while now. Is it possible to put a ZC in a 4wd Civic wagon? I think that would be a nice swap.. and then put a turbo on it.. now that's a mad sleeper. Anybody know if this will work? Oh, by the way, those things did come in 5-speed didn't they?
Old Dec 14, 2002 | 06:22 AM
MNTuner's Avatar
Default Re: ZC in 4wd Civic wagon??? (blacksheep)
Civicwagonman owns one of these chassis. Id IM him. I have herd many rumors that the only engine that fits is the d series. Unfortunately I do not know first hand though. I hope to some day
[Modified by MNTuner, 3:22 PM 12/14/2002]
Old Dec 14, 2002 | 06:41 AM
rodrez.'s Avatar
would be a cool sleeper, but I wonder how much abuse the tranny could take?
Old Dec 14, 2002 | 06:42 AM
E-AT_me's Avatar
Default Re: ZC in 4wd Civic wagon??? (MNTuner)
yes, ZC works because since it uses an intermediate shaft, it has the extra bolt holes for the 4wd system..
no, you can't do that much to them because it's not a full time 4wd system, it just engages when it notices you're slipping.. more than a few hard launches will make the "center" diff explode, which is located inside the transmission and take out the rest of your transmission..
they were available with 6 speeds.. don't get too excited, the first gear doesn't get you very far, 10-15mph at most.. it's just for getting out of slippery situations..
Old Dec 14, 2002 | 06:59 AM
altoid's Avatar
Default Re: ZC in 4wd Civic wagon??? (Rexman)
the trannies in the 4wd are stronger than their 2wd counterparts. I believe civicwagonman has a d16z6 and turbo and hes said hes beaten a few stock stangs. I've heard the whole system (4wd/tranny) can't hold much more than 170 hp, which i don't know if thats true but i plan to find out with my wagon. I've got a honda manual on the 2wd and 4wd civic wagons if you need any info or schematics or anything.
p.s. I've done a couple launches at 6.5-7k and i haven't had a problem but im also only pushing 112 hp (sohc zc baby)
Old Dec 14, 2002 | 11:59 AM
OBD1 Kenobi's Avatar
Have a look at my ZC 4WD wagon: http://wagon.crx.ca
The one thing that doesn't work out is that the proper ZC 4-2-1 exhust manifold does not fit with the 4WD. The passenger-side "2" part of the downpipe goes right where the rear hookup is on the transmission. I had to use the D16A6 exhaust manifold and its downpipe. Even a Civic Si downpipe doesn't fit. I did come across a guy who can me a custom 4-2-1 header. I just haven't given him the design yet.
Old Dec 14, 2002 | 12:04 PM
E-AT_me's Avatar
Default Re: ZC in 4wd Civic wagon??? (OBD1 Kenobi)
damn.. i've always heard different.. thanks for straightening that out for me.. now i'll be looking for a 4wd wagon..
Old Dec 14, 2002 | 12:35 PM
Now, one could install a CR-V engine and hydraulic transmission into a wagon, but would have to do the hydraulic clutch conversion. We're doing a hydro clutch on a CRX that has a CR-VTEC and ITR LSD tranny. Since the the CR-V tranny would have linkage and the wagon is shift-by-cable, some changes would be needed here. Also, getting a manual transmission from a CR-V is going to be difficult as it's rare.
Old Dec 14, 2002 | 04:54 PM
civicwagonman's Avatar
from everything i've researched, the transfer case and diff will hold up to 210hp. not sure if that was flywheel or wheel hp though. the transmission itself has much larger parts inside, looks more like a b-series trans. I tried to swapa higher 5th into mine and the shaft was alot bigger. wish I had a b trans sitting around to try. The viscous joint allows for 3% slippage before it locks. on dry pavement you really can't feel it working, but i'm only at 5psi right now. looking to up it to 10psi after christmas. we'll see how long stuff lasts then!!
oh yea, if anyone has info on the crv trannies, I'd like to know more about them, as I would like to attempt a b-series awd one day.
[Modified by civicwagonman, 5:55 PM 12/14/2002]
Old Dec 14, 2002 | 05:59 PM
altoid's Avatar
Default Re: ZC in 4wd Civic wagon??? (civicwagonman)
yeah after i rip apart my drive train from too much power im going to look into installing some b series stuff.
Old Dec 15, 2002 | 06:58 PM
seekerONE's Avatar
crv drivetrain MAY be possible...hydro conversions have been done and the CRV manual tranny is cable shifted...the same as the 4WD wagon
Old Dec 15, 2002 | 07:16 PM
kyle h.'s Avatar
it is a full time awd. and 6th speed = a low gear. its a 5 speed tranny with an extra low gear, for 4wheeling? most has been said tho...gluck
Old Dec 15, 2002 | 07:19 PM
speedy-crx's Avatar
at one time nippon had 4wd b16's witch im guessing was in the <U>"jdm sir civic wagon" </U> you guys might look into that
[Modified by needahatch, 11:20 PM 12/15/2002]
Old Dec 15, 2002 | 07:49 PM
altoid's Avatar
Default Re: ZC in 4wd Civic wagon??? (needahatch)
isn't the pilot 4wd? I say someone in here fund me so i can swap that v6 3.5l into my wagon and redo the whole drivetrain.
Old Dec 15, 2002 | 11:49 PM
Default Re: ZC in 4wd Civic wagon??? (altoid)
Are you female, cute and single? No? I ain't funding you.
Old Dec 16, 2002 | 04:07 AM
anyone have exploded views of the crv manual trans? I haven't been able to find any.
Old Dec 23, 2002 | 06:39 PM
dustincorl's Avatar
I have a B16 in one, Just built the whole car, motor , brakes etc and now it is for sale, 11,500 in reciepts, selling CHEAP havent even driven the car, ZERO (0) miles, you would not believe theis car. Everything you could want is already in it , email me and we will talk $ Just bought a new Vette
Old Dec 23, 2002 | 06:52 PM
dustincorl's Avatar
Default Re: ZC in 4wd Civic wagon??? (dustincorl)
Sorry fellows........mine is 2wd KILLER SLEEPER though
Old Dec 23, 2002 | 07:12 PM
E-AT_me's Avatar
lemme see what i can find..
try http://www.hondaautomotiveparts.com.. they have some in there.
Old Dec 23, 2002 | 08:17 PM
I had checked on there before and didn't see anything, but looks like they have stuff there now. Thanks.
Old Dec 24, 2002 | 08:55 AM
blacksheep's Avatar
Is yours the one that JSpeed did? If so, I've seen it up there.. clean car.
LowAndSlowEF
Jan 13, 2012 07:58 AM
DOHCED8
Apr 11, 2009 10:05 PM
stemiched
Nov 15, 2006 12:20 PM
1990crxhf
17
Feb 14, 2004 06:16 PM
AMChev
May 4, 2002 07:32 PM
