Mugen Lowdown vs. Zeal Function S (my review)...
Old Dec 14, 2002 | 02:21 AM
Kengs's Avatar
Default Mugen Lowdown vs. Zeal Function S (my review)...
Yes, I drive a <u>'00 Civic Si</u>, so the ITR elitists might wanna skip this thread altogether
Also, I have not done ANY roadracing or auto-x to date. I do not claim to be a suspension guru.
However, since several people have asked for my opinion about coilovers, and since nobody else seems to have hands-on experience with both, well here goes...
My Si has the following "footwork" pieces:
Carbing 3-pt front strut bar
Cusco rear lower tie bar
Mugen 20mm rear sway bar
16x7 SSR Type R wheels (12.5lbs each) with Kumho 712 (205-45ZR-16)
For the past 1.5 years, I have been using the Zeal Function S (S6 with non-adj. valving). Spring rates are FRONT: 12kg/mm (672 ft/lbs), REAR: 8kg/mm (448 ft/lbs). Lowered approximately 1.25 inches over stock, alignment performed by Gran Turismo East in Chamblee, GA (can't remember specs), not cornered weighted.
Several H-T members (Black R, Cosworth, Jason Franza, Jetydosa, etc.) have driven my car with this setup. It is quite stiff, but still tolerable for driving in ATL, GA.
I recently found a set of Mugen Lowdowns for the EK Civic that have been used for approx. 12,000 kms...these went in place of the Zeals about a week ago. Zeals are on their way to their new owner in Canada.
My impressions are as follows:
The Zeals are true race coilovers that happen to be streetable. It is pretty difficult to find the limits of these dampers driving on the street...closest I've gotten is on a deserted parking lot and on some selected stretches of (deserted) backroads. Uppermounts will squeak sometimes, and the stroke is definitely shorter than the Mugens...I've actually hit my head against the headliner a few times
However, find a smooth stretch of road and the Zeals (to me) feel spot on. Same "S" bend that I could take in the Zeals without lifting, I would feel a "push" with the Mugens at similar speed. Not exactly scientific I know, but I am 100% sure that the people that have driven my car with the Zeals (Black R, Cosworth et al) would report the exact same thing - the difference is distinct enough to notice.
The Mugens are high quality "sports shocks." The combination of longer stroke, softer progressive rate springs and rubber upper mounts means better compliance over rough surfaces and a smoother ride, but the ultimate grip is not as high as the Zeals. Also, the steering feel seems slightly less "direct" vs. the Zeals, I suspect it has something to do with the upper mounts or maybe the weight difference...
*** This does NOT make [the Mugen] an inferior choice ***
Specifically, they demand less of a tradeoff which would probably make them better suited to those who drive in areas with really bad roads (Marc). Zeals will tend to dart around on washboard surfaces, Mugens will not. Those with sensitive posteriors may tire of the stiff springs (particularly in the rear) found on the Zeals.
So it really depends on the specific conditions - good quality roads or primarily auto-x/track, I would favor Zeal...rough roads and occassional auto-x, you would probably want to go with Mugen.
Last thing to consider...BUILD QUALITY. The Zeals have endured 35K miles of street driving with ZERO maintenance. Other than some road grime, they pretty much look like new
Mugens to me look like a souped-up OEM shock:
Zeals, in particular the aluminum bodied Function S/S6, look like someone paid attention to detail:
On the rear EK shock, notice the exquisitely machined "fork"
Contrast that with the Function Basic/B6 rear EK shock (or Buddy Club Racing Spec):
You may or may not care about such things, but I do
Also, there is one MEASURABLE difference...WEIGHT
Zeal Function S (each): (F)6lbs, 9oz/(R)6lbs, 1oz
Mugen Lowdown (each): (F)11lbs, 2 oz/(R)10lbs, 7oz
I like the Mugens a lot, and honestly, I can think of no downside to upgrading from stock ITR suspension other than cost...I know Cosworth is quite happy with his Mugen Lowdowns.
<u>Still, when I am ready to purchase another set of coilovers next year, I will be looking at Zeal S6 or maybe Quantum...</u>
[Modified by kengs, 6:24 AM 12/14/2002]
[Modified by kengs, 6:41 AM 12/14/2002]
[Modified by kengs, 1:25 PM 12/14/2002]
Old Dec 14, 2002 | 02:36 AM
mpd076's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (my review)... (kengs)
Thanks for such a detailed review. I have been interested in the Lowdowns for a while. Cheers!
Old Dec 14, 2002 | 02:57 AM
Mario's Avatar
Ditto.
Old Dec 14, 2002 | 03:28 AM
len's Avatar
len
Mr. Kengs, your statement about hitting your head on the headliner is biased in my view. You must inform the public that you have a somewhat larger than usual head.
len, who has plenty of room in his kaa...105Lbs dry weight ownz!
Old Dec 14, 2002 | 03:41 AM
primoEF's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (len)
the Mugen looks so skinny
Old Dec 14, 2002 | 04:39 AM
ArmyGreenITR's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (EFDog)
cool ive been thinking of ethier Zeal or Mugen for my new 97 ITR
Old Dec 14, 2002 | 05:42 AM
RTW DC2R's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (George Knighton)
a d0pe suspension setup is way down at the bottom of my list right now. H&R sports 0wn me
Old Dec 14, 2002 | 06:28 AM
jonas's Avatar
do you live in the next room over or something?
LOL
Old Dec 14, 2002 | 07:24 AM
Ricky Rojales's Avatar
Good review. Thanks for sharing your conclusions about these two setups. That was very informative.
Old Dec 14, 2002 | 07:38 AM
sil's Avatar
sil
Can you think of any particular reason why your opinion should be less valid than it would be if your experience was with an '00 ITR?
Seriously. I know the front suspension on an '00 Si is a different design than the front suspension on the '00 ITR, but I'm not sure the difference between the suspension designs invalidates your opinions.
It is not the opinion he's concerned with but the numerous people who don't like non-itr related things on the itr board.... probably why i just lurk.. too intimidated.. to shane
Old Dec 14, 2002 | 07:58 AM
TodaSi's Avatar
Sweet post, very informative, clear and concise.
Just the way we like them
As for hitting your head on the headliner, hahaha, I cross a drawbridge here where I live and will often hit my head. Got much better when I switched to delSol seats
Old Dec 14, 2002 | 07:59 AM
Kengs's Avatar
Thanks very much for taking the time to publish this, and thanks for making sure everyone knows that it involves your '00 Si and not an ITR.
Got a dumb question, though.
Honestly George, I am not sure...
I think my wheel/tire combo is actually better than the stock OEM setup for the ITR given that my SSRs weigh 12.5 each; however, I don't have a LSD so I am not sure how much that affects handling feel. Also, I don't know how the spring rates on the Mugen Lowdowns differ from the EK and ITR versions.
Mugen Part No. 50000-XGE-K0S0
According to the enclosed spec sheet the spring rates are:
Front: 3.8-5.5kg/mm
Rear: 2.7-4.0kg/mm
Still, I think the main points about both types of shocks would transfer over to the ITR versions...the vastly stiffer spring rates, lighter construction, solid upper mounts and shorter stroke = a discernable difference between Zeal and Mugen.
I guess that was the point of the whole thread; [the differences] may have already been obvious just by looking at the specs, but I know I would hate to spend $1400 only to find out I bought the wrong suspension.
Old Dec 14, 2002 | 09:02 AM
Kengs's Avatar
Len, there's no replacement for displacement
Old Dec 14, 2002 | 11:24 AM
Black R's Avatar
25 Year Member
Don't be a sissy! Get the super functions!
Quantum? DROOL!!!
Old Dec 14, 2002 | 11:34 AM
Paste's Avatar
Loved
Default Re: Mugen Lowdown vs. Zeal Function S (Black R)
Good Review
Old Dec 14, 2002 | 11:42 AM
AB16A2T's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (paste)
Nice review.
Old Dec 14, 2002 | 12:02 PM
J_Edwards's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (AresB18C1Turbo)
Very good review..
Old Dec 14, 2002 | 12:08 PM
disordeR's Avatar
awesome review. i can't wait for my S6's.
is the valving the same between the Function S and the S6?
Old Dec 14, 2002 | 12:10 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Mugen Lowdown vs. Zeal Function S (disordeR)
Good stuff
Old Dec 14, 2002 | 12:20 PM
arren123's Avatar
The Mugens will make your car "push" more at the limit with your setup. You have quite a skinny rear sway bar (20mm). If you upgrade that to a thicker bar and set the front and rear settings right, I bet it will be just as good or better than when you had your zeals.
Not sure what the settings would be on your car, but for my ITR,
the stock front swaybar, 26mm Mugen rear sway bar and shock settings 2f/5r work great for autox.
[Modified by arren123, 1:21 PM 12/14/2002]
Old Dec 14, 2002 | 11:59 PM
Kengs's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (arren123)
I think the Zeals would probably "push" at the limit too with my setup, but the point I was trying to make is that (IMO), the limits of the Zeals are higher.
[Modified by kengs, 4:10 AM 12/15/2002]
Old Dec 15, 2002 | 12:01 AM
Kengs's Avatar
Function S is the same as S6, except the valving is fixed...think of it as being [S6]stuck on the "3" position
[Modified by kengs, 4:06 AM 12/15/2002]
Old Dec 15, 2002 | 12:29 AM
BlueR's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (kengs)
theanx for the great review shane...
i have already placed my order for the mugen lowdowns...
I CAN"T WAIT!!!!
Old Dec 16, 2002 | 04:40 AM
Back in Black's Avatar
Rather OG
Great review, Shane. Quite frankly, I probably would have went with the S6 if they had been available. It seems as if those things will never make it over here
Jason-
who had always thought the Lowdowns were adjustable, because of the cost
Old Dec 16, 2002 | 06:40 AM
BlueR's Avatar
Default Re: Mugen Lowdown vs. Zeal Function S (Jason Franza)
Jason-
darth...the shocks ARE adjustable, the height is not with the lds
