OBD0 - OBD1 - Do i need OBD1 distributor?
Old Dec 13, 2002 | 06:23 PM
EFing8's Avatar
Default OBD0 - OBD1 - Do i need OBD1 distributor?
OBD0 - OBD1 - Do i need OBD1 distributor? Please let me know.
Old Dec 13, 2002 | 07:22 PM
Tbone's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (CND_CRX)
yes. and o2.
Old Dec 13, 2002 | 10:26 PM
Blown90hatcH's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (Tbone)
yes. and o2.
Yup and a fo wire O2
Old Dec 14, 2002 | 12:08 AM
EFing8's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (Blown90hatcH)
I don't suppose anyone would trade a JDM B16 distributor for an OBD0-OBD1 conversion harness...blown90hatch i am looking in your direction. ahhaha
Old Dec 14, 2002 | 06:48 AM
Sorry friend, but that dizzy would just get kicked around with all the other extra parts I have.
Old Dec 14, 2002 | 07:33 AM
SiR831's Avatar
Does it really make a difference performance wise to run obd1? Compared to running obd0?
Old Dec 14, 2002 | 10:01 AM
ACRXGuy's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (SiR831)
Does OBD1 only require one O2 or does it have 2 also?
Old Dec 14, 2002 | 11:31 AM
CimorelliCRX's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (ACRXGuy)
1 4 wire o2. i have a obd1 dizzy for 110 shipped its yours.
Old Dec 14, 2002 | 02:09 PM
Urban Business
Guest
Posts: n/a
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (CimorelliCRX)
obd1 conversion harness @ ecu requires obd1 electronics everywhere?
i thought the obd1 conversion harness @ ecu would allow you to stay obd0 electronics but run an obd1 ecu
/me adds another $500 in parts to the list
[Modified by TorteX, 5:10 PM 12/14/2002]
Old Dec 14, 2002 | 05:22 PM
vtecrx's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (TorteX)
my d16z6 crx runs much better with a p28 than it did with the pg7/VAFC setup that I previously had. The OBD1 conversion harness requires an obd1 distributor and a 4 wire o2. You can also use the obd1 or 2 injectors if you remove the injector resistor. Check my sig.
Old Dec 14, 2002 | 05:45 PM
Pissoff's Avatar
ZORZIE
yo
i have a OBD1 conversion w a 1 wire o2
w hondata too on the ZC
WORKS !BAD
hit me in the poundrexill tell u how
Old Dec 15, 2002 | 09:08 AM
cbrman's Avatar
Default Re: OBD0 - OBD1 - Do i need OBD1 distributor? (Usdm ED9)
I dunno which motor you are using, but you can use an obd1 or obd2 distributor after converting the car to obd1. This is beneficial for d series people especially the ones doing mini me swaps. That way you dont have to cut/modify distributor ears to make it fit to the head.
Steven
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
darrenVT
18
Sep 30, 2008 09:18 AM
tRex99
Sep 5, 2004 05:28 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
h46it
Jun 18, 2002 05:23 PM
