shave side moldings help
Old Dec 13, 2002 | 05:43 PM
vtecsoldseperately's Avatar
Default shave side moldings help
im planning on DIY'ing, shaving my side moldings and was wondering if i could use sheet metal and JB weld instead of arc welding, i tryed search but this topic did not show up, anyone know if jb weld is strong enough?
Old Dec 13, 2002 | 05:51 PM
TStank's Avatar
Default Re: shave side moldings help (vtecsoldseperately)
jb weld OWNZ
Old Dec 13, 2002 | 06:41 PM
SRd240sx's Avatar
Default Re: shave side moldings help (hanuss)
JB Weld is pretty strong stuff...my friend plans on doing the same exact thing. DIY shaved moldings hehe
Old Dec 13, 2002 | 06:44 PM
ViZ's Avatar
ViZ
Default Re: shave side moldings help (98civichb)
are you planning on shaving the hole molding or just pluging the holes... jbweld... i wouldnt do it no way no how..
Old Dec 13, 2002 | 07:02 PM
Default Re: shave side moldings help (ViZ)
its for an integra, so just plugging up the holes.
Old Dec 13, 2002 | 07:08 PM
ElectronBlueGSR's Avatar
You can use my dad's welder to weld the holes shut
Old Dec 13, 2002 | 07:09 PM
Default Re: shave side moldings help (ElectronBlueGSR)
haha what if i **** up my kaa
Old Dec 13, 2002 | 07:35 PM
has anyone used jb weld.... anyone??!
Old Dec 13, 2002 | 08:35 PM
tnbigdawg's Avatar
we dont use arc welding in autobody, instead we use migwelders......arc welding will warp the **** out of your panels, or maybe even punch holes in it. JB weld??? Use it at your own risk
Old Dec 13, 2002 | 08:41 PM
Default Re: shave side moldings help (tnbigdawg)
are mig welders farely easy to use? i have a little experience with arc welders.... and anyone know what the difference is exactly?
Old Dec 13, 2002 | 10:04 PM
tnbigdawg's Avatar
Arc welders are used to weld very thick metals, an example: metal structures for buildings.
Mig welders are Electric and are wire fed and are comonly used in the automotive industry. The ones we use in autobody, are combined with a shielding gas to make the welds "pure" and prevents oxidation during the welding process. Combinations of wire speed, tempeture settings, shielding gas settings, and welding techniques all determine how your weld is going to hold up and look.
Again, JB Weld??? Use that at your own risk. I'm about 85% sure that your bodywork will crack someday.
Old Dec 13, 2002 | 10:14 PM
thanks for the advice, im steering further and further away from jb weld, but also on a budget.....
Old Dec 13, 2002 | 10:15 PM
cwestin'39's Avatar
make sure you post up a how-to tutorial on here so we can all learn to do it too.
Old Dec 13, 2002 | 10:38 PM
synergy004's Avatar
Default Re: shave side moldings help (cwestin'39)
do it the right way first, pays off.
Old Dec 14, 2002 | 04:38 PM
FredoTheChimp's Avatar
Default Re: shave side moldings help (synergy004)
jb weld owns joooo ****!!
Old Dec 14, 2002 | 08:22 PM
Default Re: shave side moldings help (Christopher_Lowell)
damn bellyville, hahahahha
KtHaNxBai
May 25, 2012 07:32 AM
HT Chaplain
Welding / Fabrication
31
Aug 7, 2007 06:41 AM
Elbowpunk
Nov 12, 2005 07:09 AM
ewn1603
13
Oct 16, 2004 03:05 PM
rice a roni
Sep 7, 2004 09:57 AM
