Fuel stats and misc from my road trip today
well, for all you pansy asses out there (who claim they want good highway milage)that swap the GSR 5th in addition to a FD swap, go to the store and buy some vagasil, cream or powder... your choice.
1998 ITR, now 95,000+ miles, stock internals. JDM FD and of course, cruise control...
940 mile trip today from FL to da burgh
Elapsed time, 13:15 (12 hrs flat act road time -> had to roll deep with NC crew for lunch)
Avg speed 70.9 mph ( 78mph deleting lunch break)
[/b]fuel consumption ~29 mpg[/b]
other consumables:
38 camel lights
2 mt. dew
4 pepsi
snickers
pack of eclipse chewing gum
lunch at bubbas BBQ
~1.5 qts of 710
1 front turn signal bulb
front left wheel bearing is on its way out.
2 stunna Fly bys
1 Volvo 18 wheeler that wanted to meet my right side fender
Bubbas,
D
other consumables:
38 camel lights
2 mt. dew
4 pepsi
snickers
lunch at bubbas BBQ
~1.5 qts of 710
2 stunna Fly bys
Bubbas,
D
how many tanks of gas did you go threw....its kinda hard for me to picture since in canada we dont go buy miles or gallons.
C'mon, now. Search Google for converters.
And then reacquaint yourself with your heritage. It's only been a few years.
Edit: Oh, and by the way: Canadian gallons are bigger than United States gallons.
[Modified by George Knighton, 9:56 PM 12/13/2002]
I think thats some pretty good gas milage, mine goes through gas like water but hearing vtec every 5 seconds would be that cause
38 cigarettes is a lot, here goes a fact----if you stop smoking, and say a pack of cigs cost 3 bux and you smoke a pack a day then you will save 1100 bux in one year
<--- non smoker if you couldnt tell already
hehe I never have either, I think #1035's previous owner was a slowpoke
well pat, other we-todds? what was keifer like behind the wheel?
rob- who knows he's done way more damage to that poor car than anyone else did
the jdm fd will land you at 4140 rpm @ 70 mph
ats with gsr 5th will land you at 4020 @ 70mph
why didnt you step up to the plate and get a more aggresive fd?
kick ***, say hi to the burgh for me. I'm thinkin i'll head up next weekend...gotta see....
you gonna strap your bike to the wing for the drive down?
keef said he average 32mpg on da way back from slopi 2000
*shrug*
*shrug*
Never really caravan'd with Queef, but it's safe to say that you're a lot harder on her than he was, Robby!
Geezus! 38 cigarettes in 12 hours?
You need to smoke something stronger than Camel Lights. Maybe Red Kamels or, my personal choice, Lucky Strikes.
d, what does a failing wheel bearing sound like? i have an annoying squeal coming from my car when the car is cold (mornings or after work) that seems to be related to the wheels; it only occurs over 30mph and goes away once the car is hot. the sound isn't affected when i go to neutral and rev the motor or upon braking. the pitch and frequency changes with the speed of the car. any thoughts?
both my bearings went recently, about two weeks part....one was really loose, so that was an obvious one...the other made a cacophony of noises...on right hand sweepers it sounded just like a failing bearing should, metal on metal spinning noise. It also sounded like crap at slow speed, like a low chirp that was tied in to wheel speed, regardless of brakes or gear. First Radley techs tried to tell me it was my aggressive pads and baked rotors (they are), but i was pretty sure it wasn't....finally got a tech to come out for a while and really listen, he concurred about bearing, now it's fixed. Car has 34k miles, can't imagine what might have fried the bearings
Quick way to check is jack the car up and see if there's any play in the wheel....most bearings won't make noises unless they're under load (i.e. on the ground)
directly dependent on speed, and usually will be affected by steering input, since the load is distributed differently on the inner and outer race of the bearing itself. also check for endplay in the hub.
This will be front wheel bearing #5 for me (ie, 2 from the factory, 2 swapped already), and they've all sounded differently to me.
ah, it must be the wheel bearings then. it is not affected by braking, steering, or motor input. it occurs over 30mph and increases in pitch with speed and is worse when cold. how do i check play in the wheels, just jack it up and shake the wheel? the car ('01) only has 33k miles so acura should warranty this, right?
hmmm, just jacked up the car and shook the wheels hard enough to rock the car and there was no movement/sound from the wheels
So whoever said that ~80 (78mph) with JDM OR ATS would be unbearable and would result in bad gas mileage..... LUBE UP!! As long as you aren't cruising in VTEC... gas mileage rules.
Nice trip D. My list would look similar except: maybe only a few cigarettes and MANY more Mountain Dews.
Drinker
