Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
air pressure in front of headlights on a 3g teg?
Old Dec 13, 2002 | 03:06 PM
Rob Dizzle's Avatar
Default air pressure in front of headlights on a 3g teg?
I am seriously considering running ducting from my high beam to a short ram intake.
From talking with other people, I have ran across the problem, that there is very little air pressure in front of the headlight. IF there was a hole in the headlight, not much fresh air would go in.
I was even thinking that air could actually want to travel out of the headlight piping that I would fabricate
I know that the real time itr's use the nsx air box and then run a a large air duct from the low beam.
Is the low beam going to have a lower "-" air pressure in front of it, compared to the high beam?
the are so close together that I would think that there should be very little difference
before i hacked away, I am going to do timed accleration tests of with the light housing in/out and see if it is beneficial to do
Old Dec 13, 2002 | 06:22 PM
JHill's Avatar
Default Re: air pressure in front of headlights on a 3g teg? (Bob-DC2)
Maybe you could do some pressure testing of the whole front end using a manometer, and map the different pressure zones. I guess you could so it in turns too to see if it had any adverse effects.
Heck, I think I might give it a try on my car.
Old Dec 14, 2002 | 10:52 AM
Rob Dizzle's Avatar
Default Re: air pressure in front of headlights on a 3g teg? (JHill)
any one else?
Old Dec 15, 2002 | 01:22 AM
rockwilda's Avatar
i remember a PY ITR had this done and placed a grill there to deflect bugs. i think his user name was Chris(???)
hopefully he sees this and responds with some good feedback
Old Dec 15, 2002 | 12:47 PM
Rob Dizzle's Avatar
Default Re: air pressure in front of headlights on a 3g teg? (rockwilda)
yeah, I am friends with chris, I am stealing his idea pretty much
but, I dont think he did a whole lota tests, or is sure it was very beneficial. I am sure its better than the stock air box, just not sure how much better it is...
Old Dec 15, 2002 | 04:53 PM
greebler's Avatar
Just do it like the GT cars do..... I would deff use the mesh, for rocks and bugs. Im not speaking from any experience but I would't see that much of an issue with pressure. Its a hole in the front of the car, it will flow.
Ryanhooligans
Sep 13, 2006 11:25 AM
George Knighton
24
Jun 26, 2006 06:13 PM
bluedevil
Mar 24, 2004 08:18 PM
LudeLC
Apr 10, 2002 10:51 AM
