Anyone use this port for turbo oil supply?
Old Dec 13, 2002 | 02:26 PM
boomslang's Avatar
Default Anyone use this port for turbo oil supply?
You have to mill the waterneck a little, but you get to run a shorter/cleaner supply line with no tees. It's a 1/8" bspt port.
Old Dec 13, 2002 | 04:50 PM
B18EG6's Avatar
Default Re: Anyone use this port for turbo oil supply? (boomslang)
dumbass
what head is that?
Old Dec 13, 2002 | 06:26 PM
boomslang's Avatar
Default Re: Anyone use this port for turbo oil supply? (AfroPuff)
It's a Jap spec B16 head. Manufacture date is 1989.
Old Dec 13, 2002 | 07:52 PM
tony1's Avatar
i used the 10x1mm port on the head, that 1 looks diff, is it b-series?
Are you talking about the one on the front of the head? If so you're in trouble because there is only oil pressure there when the vtec soleniod has 12v. You might want to change that....
Old Dec 14, 2002 | 10:11 AM
89civic1.8T's Avatar
I was thinking of running my oil line the same way. But oh well I am selling my car now.
Old Dec 14, 2002 | 12:12 PM
ninesecrx's Avatar
LS head, and its on the side. Helms says its an "Oil inspection hole". It gets 10psi.
Thats not an LS head, its a b16 head. Just look where the vtec sel. hooks up and the dist.
Old Dec 16, 2002 | 06:54 PM
E-Rok's Avatar
EPIC TUNING
i used this port but i have a b18b. much easier than running a line all the way to the back and dealing with T fitting and whatnot.
Old Dec 16, 2002 | 07:23 PM
KOTSEMOTO's Avatar
Default Re: Anyone use this port for turbo oil supply? (rewsnaeht)
Tony is right. GE has a special oil filter adaptor that has output for the oil pressure gauge, turbo oil line and LSVTEC line. No more T adaptors.
Del Sol
Jan 23, 2007 02:26 PM
O16581724 5 2 5
Dec 25, 2005 08:10 PM
RedStarGsr
Jun 8, 2004 09:37 AM
revhardsi
Sep 27, 2002 08:38 AM
Civic TSI
Aug 20, 2001 08:17 AM
