Header Bracket - is it necessary with JDM length header?
Old Dec 13, 2002 | 12:44 PM
Chris N's Avatar
Default Header Bracket - is it necessary with JDM length header?
I read all the threads I could find by searching.
I re-used my usdm stock header bracket with my JDM DC 4-1. Yesterday I noticed that Nate's new Spoon header has NO place to accomodate a bracket.
So my question is: Is it needed??
Why am I asking?? I *think* my bracket has broke, or is loose. I cannot confirm this until I get under the car and look. Either way, I have to get under there to get my test pipe off and get it shortened. So, while I'm down there, would it hurt to just take off the header bracket?
Old Dec 13, 2002 | 12:48 PM
Hooch'n's Avatar
Default Re: Header Bracket - is it necessary with JDM length header? (Chris N)
Can't use the USDM bracket with JDM header.....will brake or loosen. U can get a JDM braket or leave the header without
I am going without.
Nate B's Avatar
I didn't use the OEM bracket with my Comptech header and my Spoon header obviously seems to not be set up for use with a bracket. Who knows? I want a
Old Dec 13, 2002 | 12:51 PM
Chris N's Avatar
Default Re: Header Bracket - is it necessary with JDM length header? (Hooch at 8400-RPM)
I am going without.
Well Hooch, you can, but eventually it'll break like you said. Mine was fine at least till two weeks ago when I noticed a chattering that sounded like a loose bolt or something like that. Actually it may be intact, i have no idea. I think my suspect test pipe may also be to place, that piece of ****.
So it is safe to use no bracket?
Old Dec 13, 2002 | 12:55 PM
Hooch'n's Avatar
Yes, its safe...don't have one on the hatchcrap and will not have a bracket on the ITR after I put the header on next week.
Old Dec 13, 2002 | 12:56 PM
Chris N's Avatar
Speaking of that damned test pipe. I should call and muffler shop and try to get it fixed tommorrow. Too long, need new flange. :sigh:....
Qwikrex
Jan 22, 2003 12:41 PM
Another_Teg_Owner
Aug 3, 2002 09:53 AM
SurferX
Jun 17, 2002 04:51 AM
Tommy_Gunns
Jun 6, 2002 04:23 PM
Tommy_Gunns
Mar 10, 2002 07:00 AM
