I painted my molding
Old Dec 13, 2002 | 11:02 AM
zseeanz's Avatar
Default I painted my molding
I painted my molding with acrylic paint.....now it's chipping. What did I do wrong?
Old Dec 13, 2002 | 11:04 AM
tim anto's Avatar
Default Re: I painted my molding (zseeanz)
isnt acrylic paint the **** you use on a canvas?
Old Dec 13, 2002 | 11:27 AM
miskone's Avatar
Why wouldn't you use regular car paint. That's probably what the problem is.
Old Dec 13, 2002 | 11:38 AM
2.0L EK's Avatar
Default Re: I painted my molding (miskone)
did you spray clear over it?
Old Dec 13, 2002 | 12:06 PM
94hondaLS's Avatar
did you sand the part down first? did you use primer? also the right paint helps too. never heard of acrylic for car use. but i dont know alot about paint.
Old Dec 13, 2002 | 12:47 PM
zseeanz's Avatar
Default Re: I painted my molding (94hondaLS)
nah I didn't use primer....meybe I should have. I used car touch up spray paint. Do you think I should have used vynal paint or maybe clear coated over it?
Old Dec 13, 2002 | 01:01 PM
2.0L EK's Avatar
clear coat!
Old Dec 13, 2002 | 02:35 PM
bonk's Avatar
next time lightly sand the part first, wash it, use plastikote adheisive promotion spray which you can get at any pepboys, then primer, then paint. I did mine a year ago and havent had them chip yet.
Old Dec 13, 2002 | 04:44 PM
desync's Avatar
Nothing wrong with the paint you use..... (acrylic enamel is the cheap **** that maaco uses, don't have to clear coat when the do their cheap spray bombs)
Scuff sand it so it's no glossy (make sure it's smooth), prime it, sand it with light sand paper if it's rough, then give it a 3 or 4 *light* coats, let it dry about 20 minutes between coats. Then when it's almost dry clear coat it. First coat kindy heavy (but not running) then a couple more light coats till it looks even.
Then let it sit for a couple hours before ya drive around, some heat, or a hair dryer will help cure it if you're spray bombing outside. Just don't melt it hehe.
EDIT: Clear coat looks like *** till it's dry........ Too many coats of clear aren't bad, you just don't want runs....
[Modified by desync, 8:47 PM 12/13/2002]
Old Dec 13, 2002 | 06:59 PM
tominos's Avatar
Default Re: I painted my molding (desync)
yes, use primer, first lightly sand with light grit sandpaper, maybe 400 grit. then prime, paint, and clearcoat. that should be good.
Old Dec 13, 2002 | 08:18 PM
nak41.5LVtec's Avatar
Ive used Acylic paint on my valve covers and it looks great but it was a high temp acrylic made for motor parts. Wher your moldings rubber? If so that might of cause the flaking GOOD LUCK with your project
I My
JDM 1.5L Vtec SOHC soon to be
B18 or H22 cant wait
[Modified by nak41.5LVtec, 9:19 PM 12/13/2002]
Old Dec 13, 2002 | 08:59 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: I painted my molding (nak41.5LVtec)
acrylic is the correct paint and there are several different kinds such as enamel and laquer. Enamel is the cheap single stage paint whihc is fairly easy to shoot. Acrylic Laquer was more common back in the day and is a little thinner but has a better gloss to it. Most shops are using urethane these days which is good. Go to your nearest PPG paint supplier and get a spray can mixed up of your factory color
Jul 26, 2004 04:38 AM
FBP Si 2000
Mar 3, 2003 07:46 PM
unltdacc12
Oct 19, 2002 11:28 PM
self_made
Sep 19, 2002 10:47 AM
