How to run OBD0 injectors in OBD1 car
I am assuming the clips on my car will not plug in, but what other modifications do I need to make to have them run with my ECU? They are talon 450cc injectors. TIA
you should just be able to cut & splice NOBD injector plugs onto your OBD1 engine harness; the injectors should work with your OBD1 ecu also, but I'm not sure if you'd need the NOBD inj. resistor box....I dont think you do though.
The 92 Integra will need a resistor box to run DSM injectors. The 92 Integra's injector clips will fit the DSM injectors. So, you need to wire in a resistor box (see my sig), but you can keep your stock injectors clips.
Sonny
Randysi
Apr 4, 2012 10:17 AM
e jay one
Aug 6, 2005 02:48 PM
