DSM injecters need help real quick on install
Old Dec 12, 2002 | 08:12 PM
ProjectMurder's Avatar
Default DSM injecters need help real quick on install
k i got the RESISTER PACK from a accord and injecters from a talon awd turbo 450cc one i wana install them to a 96 GSR MOTOR what do i need to do i tried to install them but the injecter is to big for the stock o ring ....can it still work???????worrying bout leakege our something since they fit a little tight....anyone who has done this setup leme know so i can do it right.........
Old Dec 12, 2002 | 08:14 PM
DeepSi's Avatar
Default Re: DSM injecters need help real quick on install (ProJecTRacEr)
i think you have to bore out the o-rings a little to get them to fit. most people use the dermel or something like that
-deepsi
Old Dec 12, 2002 | 08:17 PM
Default Re: DSM injecters need help real quick on install (DeepSi)
yea thats it what horsepower can these injecters handle up to with a afc and a map controller that adds fuel during boost leme know
[Modified by ProJecTRacEr, 9:17 PM 12/12/2002]
Old Dec 12, 2002 | 08:47 PM
MiraiZ's Avatar
250-300whp
you can also clamp down the fuel rail...the injectors should just slide into the seals.
Old Dec 12, 2002 | 08:52 PM
Default Re: DSM injecters need help real quick on install (MiraiZ)
so use the stock gsr o rings and there will be no leaks? only 250-300horsepower on 450cc? thought could atleast get 400-450 and the dsm injecters fit kinda higher then stock so do u put washers on the fuel rail?
Old Dec 12, 2002 | 08:57 PM
MiraiZ's Avatar
stock seals should be fine..
I'd go 550 or bigger for that much hp...watch the duty cycle, if its at 80% or higher at WOT...then its bigger injector time!
Old Dec 12, 2002 | 09:15 PM
[Modified by ProJecTRacEr, 2:10 PM 12/13/2002]
Old Dec 12, 2002 | 09:19 PM
ignore that last post where u find the duty cycle at bro thanks for all the info
sCeRaXn
Nov 3, 2003 10:27 AM
turbod16y8
Mar 20, 2003 04:30 PM
boostinb18
Mar 10, 2003 10:44 PM
AudioXtremes
22
Sep 7, 2002 10:08 AM
