Polishing a Valve cover.
Old Dec 12, 2002 | 07:06 PM
Dancing is Forbidden's Avatar
Default Polishing a Valve cover.
What is the best way to polish the valve cover so it is really clean and shiny? Not too much into looks but want to do this. Thanks guys.
Old Dec 13, 2002 | 03:05 PM
97 BB6's Avatar
Default Re: Polishing a Valve cover. (EF9_SiR)
Start off using rough sand paper (120 grit) then work your way to 300 grit, then 600 grit, then finish with fine steel wool. be sure to sand in a straight line. takes a few hours.
Mine is not completely done but here it is...
http://www.imagestation.com/mypictur...&id=4243572946
[Modified by 94 EJ1, 12:06 AM 12/14/2002]
Old Dec 13, 2002 | 05:25 PM
SiK AcC0rD's Avatar
Default Re: Polishing a Valve cover. (94 EJ1)
that actually doesnt look bad...
Old Dec 13, 2002 | 05:37 PM
gleinz's Avatar
Default Re: Polishing a Valve cover. (SiK AcC0rD)
How do you take the valve cover off?
Old Dec 13, 2002 | 07:15 PM
MyBigNut's Avatar
Default Re: Polishing a Valve cover. (gleinz)
unscrew it
Old Dec 13, 2002 | 08:43 PM
Mase's Avatar
Default Re: Polishing a Valve cover. (MyBigNut1)
id go w/ some 200, 400, 800, 1000, 1500, 2000 if you really want it blingy, then get a dremel polished kit, and some mothers polish
Old Dec 14, 2002 | 11:06 AM
97 BB6's Avatar
Default Re: Polishing a Valve cover. (Mase)
it was my first time and I just guessed on the sandpapers to use. I didn't even unscrew it. Just remove the spark plug wires and A couple other things like the oil cap (be sure to plug the hole though with a cloth or something) I am not completly satisfied with it but it looks a hell of a lot better than it did stock.
Oh by the way you can also remove the plastic off of your battery tei down and polish it as well. (It is hard to see in the pic)
[Modified by 94 EJ1, 8:08 PM 12/14/2002]
Old Dec 14, 2002 | 01:03 PM
BrokenVtec's Avatar
i agree do those steps... 200, 400, 600, 800, 1000, 1500, 2000 wetsanding and once your done a nice healthy coat of mothers aluminum polish
Old Dec 16, 2002 | 05:30 AM
SM Polishing's Avatar
Default Re: Polishing a Valve cover. (BrokenVtec)
Be sure to remove ALL casting dimples before the final buffing to the reflective shine. Also if you have access to a buffing wheel it will help get the majority of the polishing out of the way so you can just do the tight spots with a dremel, helps save some time.
Check out my website if you want some examples, email me if you have any questions.
Scott
Old Nov 18, 2006 | 11:27 AM
BoOsTiN Dc2's Avatar
Default Re: Polishing a Valve cover. (SM Polishing)
can you do this with a dremel or do you have to do it by hand?
Old Nov 18, 2006 | 12:11 PM
XSCIVIC93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenVtec &raquo;</TD></TR><TR><TD CLASS="quote">
i agree do those steps... 200, 400, 600, 800, 1000, 1500, 2000 wetsanding and once your done a nice healthy coat of mothers aluminum polish</TD></TR></TABLE>
yep... a polishing wheel will make it look the best. heres mine i did about 3 years ago, all by hand. picture was taken about 2 months ago
Old Nov 18, 2006 | 12:14 PM
aaronISthrowed's Avatar
Default Re: Polishing a Valve cover. (XSCIVIC93)
I did mine by hand, took a few days and about 2 hours per day. Ill go snap a few pix...
Brooklyn101
Welding / Fabrication
11
Aug 14, 2010 08:18 PM
b20beast83
Feb 4, 2009 01:23 PM
hatchback19
May 30, 2003 11:13 AM
Simple
Nov 22, 2002 06:10 AM
TeamTooQuick
May 22, 2002 01:20 PM
