AEM EMS owners...
Old Dec 12, 2002 | 02:46 PM
LJR-LUDE01's Avatar
Default AEM EMS owners...
for those who have EMS can you post some pics were you install it....
Old Dec 12, 2002 | 03:09 PM
satan_srv's Avatar
Default Re: AEM EMS owners... (LJR-LUDE01)
What? you take your ecu out, you put the AEM in. Same spot.
Old Dec 12, 2002 | 09:36 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS owners... (satan_srv)
hmm I tough it was attach to your ecu... thanks satan_srv...
Old Dec 12, 2002 | 09:56 PM
satan_srv's Avatar
Nope, the AEM EMS is a complete standalone unit.
Old Dec 12, 2002 | 09:58 PM
PreludeVTEC01's Avatar
yep, you take out your oem ecu and replace it with the EMS system
Old Dec 13, 2002 | 07:49 AM
boomslang's Avatar
Default Re: AEM EMS owners... (PreludeVTEC01)
It's too big to fit in the stock location. There is no way mine would fit under the 4th gen ecu plate.
Old Dec 13, 2002 | 08:04 AM
Quaalude's Avatar
Default Re: AEM EMS owners... (boomslang)
On the 5th gen., I cutoff the center support bracket on the metal plate. With the EMS in the stock location, I then screwed on the bottom nuts onto the lower studs, left enough room for the metal plate to clear the ems, and left a little edge protruding from the studs/nut so the metal plate can rest/catch it. Then I screwed in the top nuts all the way down and placed a folded up shop rag between the ems and metal plate. It looks just like stock all covered up.
Old Dec 13, 2002 | 10:37 AM
BoostedH23a1's Avatar
Default Re: AEM EMS owners... (Quaalude)
what did u pay for it..1300?
Old Dec 13, 2002 | 11:56 AM
LJR-LUDE01's Avatar
Default Re: AEM EMS owners... (BoostedH23a1)
1250 for mine...
Old Dec 13, 2002 | 12:27 PM
hondaZvic's Avatar
can the AEM EMS control all of the functions for ur turbo ? like boost control? turbo timer? what ever else there is for the turbo electronically
Old Dec 13, 2002 | 01:40 PM
Quaalude's Avatar
Default Re: AEM EMS owners... (hondaZvic)
Around 1250 shipped for mine also.
Yes, the ems can control boost. You will have to get a GM solenoid and wire it up to the ems. The solenoid is like $12. The ems also has knock control, 2 step rev limiter, N2O control, and a bunch of other features. It has a turbo timer feature but for stepper style idle control motors only (Mitsu and Toyota I think). Can't use it on the Honda pulsewidth idle control.
Old Dec 13, 2002 | 02:15 PM
boomslang's Avatar
$1050 for mine.
Old Dec 13, 2002 | 02:42 PM
LJR-LUDE01's Avatar
arggg so you telling me I didn't need the boost crontrol???? argggg oh well... I guess I'll be selling a Profec-B here soon
Old Dec 13, 2002 | 05:11 PM
holy **** can i get one for my 94 prelude for 1050? if so where..
Old Dec 13, 2002 | 05:21 PM
also how much did u spend on tuning...
Old Dec 13, 2002 | 06:29 PM
boomslang's Avatar
Classifieds. New in box!
Old Dec 13, 2002 | 07:35 PM
GZERO's Avatar
can you comment on it, the ups and downs on your specific car, how the instalation was and all that and how was the tunning?
Old Dec 14, 2002 | 03:44 PM
boomslang's Avatar
Default Re: AEM EMS owners... (GZERO)
I've just messed around with it a little. The learning curve is kinda steep. I haven't finished building my motor yet, so I am just using it on the stock sohc.
Old Dec 14, 2002 | 03:54 PM
Quaalude's Avatar
Free, tuned it myself. Like boomslang said, the learning curve is steep but if you read all the documentation and understand how the ems works, it isn't all that bad.
Old Dec 26, 2002 | 08:15 PM
2000TypeSh's Avatar
That's cool if someone is selling them locally or you can just go to importparts.com. They don't have them listed but I did get a price of $1136 for my h22A4.
They said this isn't even a special.
Old Dec 31, 2002 | 12:19 AM
h23vtec_dc2's Avatar
Default Re: AEM EMS owners... (2000TypeSh)
when you swapped in the aem ems w/o touching it or doing any tuning, did you feel a difference?and why do you think so?
Old Dec 31, 2002 | 05:15 AM
jbx's Avatar
jbx
$1050 for mine.
Where did you get it for this pricing ?
Old Dec 31, 2002 | 05:21 AM
BlueShadow's Avatar
Default Re: AEM EMS owners... (mugenb18c)
Any standalone that comes with base maps needs to get tuned.
Apexi PFC users for example tell the seller what mods they have and the seller gives them a base map to work with. The base map will be good enough to get the car running, but you still need to get it tuned to your specific setup, temperature, etc.
I believe AEM EMS vendors sell their units with some base maps so you can have a car that starts but I'd have to check that with an AEM seller. But if so, then just like the Apexi PFC I you would have to fine tune it.
Old Dec 31, 2002 | 08:43 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: AEM EMS owners... (BlueShadow)
does anyone know if the AEM EMS eliminates the immoblizer feature on the 97+ Preludes???
Old Dec 31, 2002 | 09:23 AM
satan_srv's Avatar
Default Re: AEM EMS owners... (Boosted97Lude)
Of course it does. Your old ecu is gone....
madjdmek9
Sep 3, 2013 04:40 AM
Imadreamer1226
Jan 17, 2006 03:50 PM
Rabid Machina
Jan 15, 2006 09:45 PM
firstclassjdm
Jan 31, 2005 03:19 PM
