need help with my trans prob
how much are syncros? should i just buy a new EX trans? ive got a DX....
go to honda, get 2 quarts of Honda MTF and replace your transimssion fluid.
that could stop the grind. if you say its only at high RPM's its possible it will fix the grind.
if it dosent, you have 2 options
1) replace the syncros wich can be costly and if you dont do the work yourself, the labor charges will be more than a new transmission
2) replace the transmission, but then you take the risk of getting a shitty transmission, and being stuck with a diffrent problem.worse problem.
