Fudge! My new intake dosn't fit....
I ordered a Injen RD CAI and just got it today, but it doesn't quite fit. I ordered the one for the GSR. I fit's up ok to the TB but it's just that it's a little long. Like the tube almost touches the ground with out the filter on the end even. I guess I'll just have to cut off a little bit on the end and then it should work ok.
Should I have ordered the one for the 99 civic EX or something? I know the one for the DX wouldn't have worked because the TB was straight up.
I don't know, i will make it fit nice.
[Modified by sivik2nr, 2:45 PM 12/12/2002]
You should have ordered the one for the Si. The D series intakes are a smaller diameter than the b-series. The GSR would should work fine though once you get it modified to fit.
I take the post back.. once I cut that bracket alittle shorter ( the brace one ) it fits perfectly..
So for the record , one piece CAI for gsr's will fit in 96 + civics with the GSR motor.
