which wastegate? hks vs tial
it is an h22 pushin 25+psi, 500+ whp, at the track. less on the street of course, but it needs to handle the duties of the weekend. both are 40 mm. the price is about the same, from what i have found. also how hard is it to chang the springs?
thanks guys, went w/tial. .45 bar spring, low boost in first, ~2 bar in 4th via an avc-r(maybe)
I dont think the 35mm Tial will hold 2 bar. This is what my problem is...think im going with the 40mm gate.
with the tail you can only double your boost. so if you have a .45 bar spring, the highest you could run is .9 bar or around 13.9 psi
seems weird... i thought when you installed a boost controller the spring was bypassed... ??
with a boost controller on any tial you can go way past double as long as your turbo can produce the boost it needs to suffice the air flow.
The tial 35mm are good in the range of 350-400hp anything above that use the 40mm or 46mm the hks wg is also good choice but the flanges are way different that most of the std wg you see .
yep, thats why i went 40 mm, starting to wonder if i should have went 46 mm
