quick...... will a clutch from a 98 dx work on my 90civic si?
ttt dude says it has 32k on it, and wan't $35 for it. good deal or not?
will it work on my 90 civic si D16a6 ???
it will bolt in... u can put the whole pressure plate and clutch disc onto ur flywheel... i used a 93 Si clutch in my 90 STD once... worked fine since the flywheel surface was the same... i bet its the same in ur case... ill say pick it up if its not bad.. wich in my case sounds fishy
Canadian_EF
17
Mar 24, 2011 11:39 PM
hondamaker1211
29
Sep 27, 2010 03:55 PM
legacytunes
Apr 8, 2004 09:18 PM
