Mounts...Engine or Transmission?
Honda Integra 94 VtiR
similar to a GSR
Recently after experencing wild wheel hop, on launching, i noticed my gear shifter move slightly when i reved it, it 2500 and onwards, and the movement was only an inch, i have experenced this before in a pervious car and as a result have had to replace a front engine mount, my guess is there is a bit of movement by the engine when reving, and becuase the engine is connected to the transmission, the whole lot moves, margionally.
My problem is i dont know which mount or mounts are broken/ or rubbers torn. After reading the forum a little i think it has to be a mount which prevents engine from moving back and forward, becuase when you rev, the engine dips forward and the gear shifter also moves forward, theredore i seem to think out of the five mounts in the engine bay, it should be the transmission mount but when i rev it i dont see an awfull lot of movement there.
Is there any way i can diagose this acurately so i can fix the right mount.
[Modified by lukejurg, 12:42 PM 12/12/2002]
similar to a GSR
I gave you my reply here: https://honda-tech.com/zerothread?id...613131#3613131
Please don't double post.
vortexx
11
Dec 20, 2006 11:29 AM
lukejurg
Dec 12, 2002 05:20 AM
