what are some causes of your lights diming
Old Dec 11, 2002 | 07:40 PM
Buckshot's Avatar
Default what are some causes of your lights diming
when my car is revved up the lights get brighter, also the fan goes faster.
does this mean my battery is dying? is ther anything else it could be besides the battery?
Old Dec 11, 2002 | 07:42 PM
LSVTEC96HB's Avatar
Default Re: what are some causes of your lights diming (Buckshot)
if your car is a honda, you probably have a problem with the ELD electrical load detector. try a search and see what you come up with
Old Dec 11, 2002 | 11:05 PM
dr650's Avatar
New User
Default Re: what are some causes of your lights diming (LSVTEC96HB)
if u dont have any check engine light ,check ur alternator might be the nut is loose.or anyything
Old Dec 12, 2002 | 07:43 AM
Arsenal's Avatar
Default Re: what are some causes of your lights diming (dr650)
Alternator, you might find some changes in your radio quality just before it goes, everything weakens. Then nothing.
Old Dec 12, 2002 | 08:49 AM
Buckshot's Avatar
Default Re: what are some causes of your lights diming (Arsenal)
i just had my timing belt and all my belts changed...do you think it could have something to do with this?
Old Dec 12, 2002 | 09:31 AM
vtec69's Avatar
maybe weak alt?
-Brian
Old Dec 12, 2002 | 09:58 AM
dr650's Avatar
New User
check ur belt.might be loose<<
Old Dec 12, 2002 | 06:14 PM
Benj's Avatar
Had similar problem. With the lights on, sometimes the radio goes dead and the dashboard lights goes dim. Turned out it was just the battery not receiving enough voltage. Just a quick 15 min charge from the local battery dealer was enough to solve the problem.
Old Dec 12, 2002 | 06:27 PM
HonaTek1's Avatar
probably weak alternator
Old Dec 12, 2002 | 08:11 PM
Buckshot's Avatar
Default Re: what are some causes of your lights diming (HonaTek1)
damn it that would be a bitch
firefighter509
Acura TL, RL & ZDX
Sep 28, 2011 02:36 PM
that_boy_sammy
May 18, 2011 04:55 PM
justinwebb
Mar 9, 2009 11:45 AM
Keno20
Jul 3, 2005 07:27 PM
