GSR question
Old Dec 11, 2002 | 07:03 PM
icelarry27's Avatar
Default GSR question
if i stroked a gsr and sleeved it to run 13:1 compressino pistons, what do you think my car will run, with just that stuff, not even i/h/e
Old Dec 11, 2002 | 07:16 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: GSR question (GRCuadros)
a fully built and sleeved motor without a header intake and exhaust, sounds like we have an enthusiast here.....
Old Dec 11, 2002 | 07:46 PM
Shawn C's Avatar
In The Garage
Default Re: GSR question (SIXTYdashONE)
with 13:1 compression, you would only run......away from the exploding car
Old Dec 12, 2002 | 05:15 PM
icelarry27's Avatar
im gonna get a i/h/e an cam gears an cams and an intake manifold an all but just not so soon..i wanna get it sleeved and stroked first....what do you guys thinK?
Old Dec 14, 2002 | 12:51 PM
jdmDXrex's Avatar
are you sure you know what you are talking about.... what are you going to stroke the motor to? the 87.2mm stroke NOT 97.2 (my bad thanks adam) is fine just sleeve it and going 13:1 compression is enough.... your not going to be able to take advantage of your motors true potential until you port your head, get some injectors and get a decent valvetrain in there....
basically your motor wont get any better unless you get MORE AIR AND MORE FUEL in there for that high compression and increased displacement.....
[Modified by jdmDXrex, 4:33 PM 12/14/2002]
Old Dec 14, 2002 | 02:45 PM
Kataku2K3's Avatar
Default Re: GSR question (jdmDXrex)
I know you know this Mike but it's just a mis type 87.2mm stroke, I agree with you tho Mike.... Just like our setup... 85mm bore B18C with stock crank... Latez
Old Dec 14, 2002 | 06:50 PM
96dc2's Avatar
Default Re: GSR question (JDMspecEG6)
with that compression isn't he undercammed?
Old Dec 14, 2002 | 09:29 PM
jdmDXrex's Avatar
Default Re: GSR question (96dc2)
if he uses just stock gsr cams... yes he will be undercammed but all he needs is a CTR/00+ ITR intake cam and he can make plenty of power. i have a few friends running b20vtecs with 12.5:1 compression making 215+ whp with ctr intake cam and just gsr exhaust cam with portflow heads and 310 injectors.
a CTR intake cam will do fine
Old Dec 15, 2002 | 03:20 PM
icelarry27's Avatar
so if i get my head ported, an get my block sleeved and get my engine stroked to 2.0 liters (with i/h/e by now) i should be makin alot of power?
Old Dec 15, 2002 | 03:36 PM
Kataku2K3's Avatar
Why are you sleeving and stroking??? I don't get this... You can get to pretty close to a 2.0L by just sleeving to 85mm... That's ~1.98L motor... You aren't gonna get the power just from physically doing the work... I seriously wouldn't doubt that if you tried to run that motor with 13.0:1 compression with a STOCK ECU that you would lose power over a stock GSR and most likely blow up your motor... To make 13.0:1 streetable requires a lot of tuning as just building the motor.... Just remember tuning is the key to POWER!! Latez
Old Dec 15, 2002 | 03:42 PM
Kataku2K3's Avatar
Also most high compression motors like a lot of overlap but a CTR will be fine just as jdmDXrex stated... Peace
Old Dec 15, 2002 | 11:27 PM
Rukkus233's Avatar
Default Re: GSR question (JDMfckin21)
Dude, what the **** do you know about that ****??!?!? Your a gay *** mother ****** who thinks you know a whole bunch of **** about ******* cars. you and your car, that what, you dont even have? Oh ****, watch out! man I will show you, I have a CRX stripped all moter that can run 12.79, you think you tough ****?!?! what now!
Damn, we gotta tough guy on the board. Betta watch out.
Old Dec 15, 2002 | 11:33 PM
Kataku2K3's Avatar
Default Re: GSR question (CheddaBob)
Yea you're right JDMfckin21 I don't know what i am talkin about.... I'm only 18 and I'm dumber than ****.... Sorry I posted I won't do it again... Sorry
Old Dec 16, 2002 | 12:27 PM
icelarry27's Avatar
dude who are you talking to? because ill admit...i dont know all that much...thats why i come here, to learn stuff so that i don't fuckup my motor, and if your not talking to me, well stop being such a pessemistic flamer!
back to the topic, i'd have to get my motor completely built basically to make 13.0:1 compression work on the street? alright well atleast i know more than i did before, now maybe i won't fuckup my motor, thanks man
[Modified by GRCuadros, 4:29 PM 12/16/2002]
Old Dec 16, 2002 | 12:36 PM
jdmDXrex's Avatar
JDMfckin21....... I seriously hope you are kidding.... 12.79 all motor in a stripped CRX???? THATS IT?.... HOLD ON...
hahahahahahahahahhahahahaha....... (note to self) breathe
hahahahahahahahahhahahahaha ...... (turning purple...)
ROTFL.....hahahahahaahahahaha
i dont even have the equilvalent to a stock gsr motor and im running 13.2 full interior.....
well anyways my stomach hurts from laughing so hard so see ya latez
Old Dec 16, 2002 | 03:09 PM
Kataku2K3's Avatar
haha Mike this is some funny *** **** huh....
Old Dec 16, 2002 | 07:17 PM
95GSRRacer's Avatar
Old Dec 17, 2002 | 02:04 AM
NiiS's Avatar
The importance of what you just said is something that deserves to be repeated
Old Dec 17, 2002 | 04:14 AM
Ricky Rojales's Avatar
:fire:
Old Dec 17, 2002 | 04:21 AM
I feel a ban coming on.
Old Dec 18, 2002 | 11:16 AM
icelarry27's Avatar
ok ill be honest...i dont know all that much about cars...what i do know is that i want a gsr engine, i wanna run 13:1 compression, safely, have a quick and nice car...i just need some help, how hard is it gonna be to run 13:1 on a street car...what exactly am i gonna have to do...thanks for all the help guys
Old Dec 18, 2002 | 04:47 PM
Kataku2K3's Avatar
For starters sleeve the block.... 13.0:1 is goin to put a little bit of stress on the sleeves... As i said before look into Golden Eagle.... You could get away with stock rods but it would probably be better to upgrade to Eagle or something along those lines... Eagle is fairly inexpensive... Then the headwork... For 13.0:1 you will want a head that flows pretty well, I would definately recommend Portflow, Tom does awesome work... As for cams with that kind compression you would be fine going with high lift long duration cams, anything from JUN3's, Toda B's/C's, or Skunk2 2's/3's..... Any of those cams with the proper tuning will make power... I don't know what octane you got around you but with 13.0:1 the margin of tuning pump gas is pretty small... It's definately possible with Hondata or something but it's going to be a little work... TUNING is the main thing you are goin to be worrying about... Without it your motor just isn't goin to last... Mixing race/pump gas will open up your tuning margin more but then that is just extra $$$$.. TUNING = everything and safety... Good Luck
Old Dec 19, 2002 | 05:34 PM
icelarry27's Avatar
thanks alot man...you all have been really helpful...
Old Dec 19, 2002 | 09:54 PM
Kataku2K3's Avatar
Dude, your CRX is shitty! You think you tough ****!, you must be smokin too much buddy, you and your gay *** friend can just go suck each others short skinny little *****. Never, and I mean never, laugh at me, come on I will take you any day, lets see whos laughing then? Until you can ever smote me, just go and **** your mom!
should we block his IP???
[Modified by JDMspecEG6, 10:54 PM 12/19/2002]
Old Dec 20, 2002 | 03:42 AM
MrFatBooty's Avatar
General rule is to work your way from the outside in. Get the standard bolt ons, then cams, then think about building up the block. There's not really a good reason to go the other way around because a high-comp bored out block isn't going to do a whole helluva lot of good breathing through the stock intake and exhaust tracts.
