Got my J's intake today....
Old Dec 11, 2002 | 05:58 PM
Dr Pooface's Avatar
Default Got my J's intake today....
Just finished my first drive with it on, and I like it. Noticably more power low and midrange over my ghetto homemade CAI. Tone is deep and throaty throughout. One question, though..... a silver "L" bracket was included and I can't for the life of me figure out where it goes. Anyone....? I know the info I need is in a thread from a while back, but the search doesn't work too well right now. TIA
Old Dec 11, 2002 | 06:07 PM
B2FiNiTY's Avatar
Default Re: Got my J's intake today.... (Dr Pooface)
I also got that but no luck.
Old Dec 11, 2002 | 06:10 PM
NunRacer's Avatar
So it finally came in. Perfect. I thought you had the stock intake?
Old Dec 11, 2002 | 06:11 PM
B2FiNiTY's Avatar
Default Re: Got my J's intake today.... (NunRacer)
Here's the bracket. I emailed Yasu @ ATS USA but he seemed rude and asked where I bought my intake. I then replied that I didn't buy it from him but I needed help. He never replied back
Old Dec 11, 2002 | 06:13 PM
NunRacer's Avatar
Default Re: Got my J's intake today.... (B2FiNiTY)
I think that bracket hooks up to the tranny some how. My short ram intake that I have now has that same kind of bracket.
Old Dec 11, 2002 | 06:14 PM
B2FiNiTY's Avatar
Got a pic of how it is mounted?
Old Dec 11, 2002 | 06:22 PM
disordeR's Avatar
i wanna see some dyno results!
Old Dec 11, 2002 | 06:24 PM
NunRacer's Avatar
I'm going to work now so I can't get a pic. After work I will try to get a pic.
Old Dec 11, 2002 | 06:28 PM
done's Avatar
i also got this bracket, what did you guys do about the a/c lines?
Dr Pooface's Avatar
I had modified my intake to eliminate the resonator.
Old Dec 11, 2002 | 06:29 PM
Dr Pooface's Avatar
Default Re: Got my J's intake today.... (Jordo)
Canadian R's don't get A/C.
B2FiNiTY's Avatar
I did nothing to them. I just checked the J's after 1 month and there is no dmg to the intake. Although...the soft stuff on the a/c lines have been squashed. J's 0wnz my dad's A/C lines.
Old Dec 11, 2002 | 06:48 PM
done's Avatar
my intake filter has a little rub on it
Old Dec 11, 2002 | 06:55 PM
B2FiNiTY's Avatar
Mine rubbed with my hood but I pressed it onto my A/C lines and it fixed it. One or the other...
Old Dec 11, 2002 | 06:56 PM
zer0zer0 TypeR's Avatar
Default Re: Got my J's intake today.... (disordeR)
i made 176whp with toda header, j's intake, and jdm 2.5" exhaust with a 2.5" testpipe.
Old Dec 11, 2002 | 07:13 PM
Stock R's Avatar
Default Re: Got my J's intake today.... (zer0zer0 TypeR)
ooooooooh.
where's my j's? not that i can test drive it anywayz. but don't worry, let the engineer figure out where the L bracket goes when he gets his intake.
Can someone post a pic and circle which ones are the A/C lines? I don't have a clue.
Old Dec 11, 2002 | 07:14 PM
d8168055's Avatar
Default Re: Got my J's intake today.... (Stock R)
does a 3" filter fit?
Old Dec 11, 2002 | 07:17 PM
hungsteR's Avatar
Default Re: Got my J's intake today.... (d8168055)
I think the intake diameter is 4".
Old Dec 11, 2002 | 07:29 PM
disordeR's Avatar
do you have a graph?
Old Dec 11, 2002 | 07:58 PM
Spikey's Avatar
Glad you like it
Old Dec 11, 2002 | 08:48 PM
yea but jeff@IB hasn't emailed it to me yet, trust me it's valid.
Old Dec 11, 2002 | 08:51 PM
disordeR's Avatar
never doubted your numbers, just wanna compare your graph to my. (although i know numbers from dif graphs don't mean much)
stock timing, a/f settings, and vtec engagement?
Old Dec 11, 2002 | 09:10 PM
stock timing, 5300rpm vtec, 8600rpm rev limit. gained 15whp from 5500rpm-6000rpm with hondata s200 ecu stage 3. max hp 176. but this was before i got my valves adjusted and running on crappy plugs and wires. hopefully i'm pushing out a tad bit more than that, around 180whp.
Old Dec 12, 2002 | 12:31 AM
Q-OnE's Avatar
man...its going to be hard to explain this. the "L" thing is used just in case you want to bolt it down to a near by bolt around the intake area. its likea brace so it won't shake around.
Old Dec 12, 2002 | 12:36 AM
B2FiNiTY's Avatar
Default Re: Got my J's intake today.... (FeeL's gs-R)
I just couldn't find a place for it man! If you got any ideas. Show me. I'll bring the mounting thing to the drags.
