si cluster
Make sure the cluster you have is from a 90 or 91. There are 2 screws on the front side of the cluster cover"there are plastic caps over them" Can't remember if there are some on the back side. That should pop out. Then Just look for mounting screws for the cluster then unplug the DX cluster adn plug the Si one in and put back together.... May seem confusing cuz I did write this fast.... Anyway good luck....
Mr Boston
Sep 6, 2003 10:00 AM
