Swap Help
Old Dec 11, 2002 | 03:12 PM
SikofFalln's Avatar
Default Swap Help
I am putting a B16 out of a 99si in my 92 civc si, here's the problem. I am using the 92 harness on the 99 B16, I swapped out the injectors with the D16 (they flow the same) so everything would plug up, but here lies the problem. The altenator plugs are different. How do I go about fixing this? Do I swap out the plugs? If so how can I figure out which pin goes where? Any help is greatly apprectiatted.
Old Dec 11, 2002 | 04:11 PM
riceboy's Avatar
Default Re: Swap Help (BseriesPWR)
what do the plugs look like, there are a few different types of plugs that are used on the distributors, pics would help.
Check the 94 del Sol B16A2 distributor, it might fit, go to a honda dealer and ask them in the parts department to let you see one and compare the bolt pattern to yours, make sure the bolt pattern will match up and then if the plugs are the ones you needs then there you go, The other distributors that I would think to check that might work for you are the OBD1 LS distributors or the 92-93 GSR distributor, just take your distributor to a local honda and acura dealer and match them up with what you need.
Old Dec 11, 2002 | 11:38 PM
salbaje's Avatar
yes you can repin the alternator to fit your harness or get an obd1 gsr or delsol vtec alternator. did you change your distributor also to obd1??
sirminder
Aug 21, 2011 02:38 PM
turboteg90
Jun 16, 2008 05:17 PM
TribusRacing
Feb 21, 2006 07:23 PM
JDM00SI
Aug 15, 2005 11:26 PM
