ATTN: blown90hatch, or anyone else who has done a obd1 conversion
Did you get one of his conversion harness? If so, there should be a wire that you connect to the positive wire of a toggle switch. If engine light is on, flip it once and it will give you a code.
[Modified by CrxSi10, 1:51 AM 12/12/2002]
I believe its D4 from looking at this. Pinouts for Obd-1 to Obd-0
Whats is a toggle switch.. And if I bought the harness from blown hatch witch i did like a year ago... Does it work on any ef.. as in dx si hf.. It seems like it would need pinned differntly..
A toggle switch is a switch that uses a toggle joint with a spring to open or close an electric circuit as an attached lever is pushed through a small arc.
As for your other question, I believed you have to convert it to multipoint fuel injecition first like hf and si. I'm not really sure you have to contact blownhatch for that.
I bought one of his harness awhile back and installed it on my 91 si and had no problems with it, works great.
You will need to convert your car to MPFI first, then you can run the harness. I can convert that for you if you prefer. Email me if interested.
For the check engine light, you can just ground D4 (obd1 side) when you throw a code, or you can wire D4 to a toggle switch and on the other side, ground the other pin on the toggle switch.
Jason
Jason
thanks jason, btw the conversion worked out great
if you guys need harnesses, buy from jason, he's a great guy
On others you just have to jump the connector for the distributor timing.
[Modified by MNTuner, 6:06 PM 12/15/2002]
