Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Oil Dilemma
Old Dec 11, 2002 | 01:18 PM
Cal's Avatar
Cal
Default Oil Dilemma
Can you go from using a fully synthetic to a regular oil?
I currently run a Mobil 1 5w30 synthetic, but am thinking about switching to a regular oil simply because I change it every 1500 miles and cannot keep spending $40 on oil. Synthetic is $8.00 a litre here.
I have only ran synthetic for about 5000 miles in my B16A, and dont think its too late the switch back.
Anyways is there any hard evidence that you cannot go from synthetic to regular, even after so little milage on the synthetic?
I simply cant afford the cost of the synthetic oil and change it soo often that I am not benefitting from a full synthetic.
Opinions welcome & appreciated
Old Dec 11, 2002 | 01:45 PM
gtpilot's Avatar
Default Re: Oil Dilemma (Cal)
You should not have any problems witching back do dino squeezings at all. You can run a blend of synth/dino too...
Kirk
Old Dec 11, 2002 | 01:46 PM
solo-x's Avatar
first off, why do you change it so often? do you track every weekend??
second, no there will be no problem. most problems stemming from synthetic oil use is due to it being used too early in the break in cycle, preventing the rings in the motor from fully seating. switching back doesn't hurt anything, but people think _that_ is the reason their motor uses oil instead of the real reason of the motor not being broken in properly. somebody posted an excellent link concerning engine break-in procedure, maybe they'll post it again or you can search for it.
nate
Old Dec 11, 2002 | 02:26 PM
.RJ's Avatar
.RJ
Default Re: Oil Dilemma (solo-x)
http://forums.improvedtouring.com/it...ML/000433.html
nate
Old Dec 11, 2002 | 05:58 PM
Cal's Avatar
Cal
well as of now no i do not. I change it before and after coming back from the track as everyone should. I will probably track every 2 weeks in the summer and will religiously change it as it is needed.
I do this because my engine is a 92 and although scores good compression, it is a small price to pay to get maximum protection. I just cant afford parts and frequent fully synthetic oil changes, and when driven around ***** footed i will extend it to 2500 -3000 on a change. The fact is that it is rarely driven around lightly as the car isnt comfortable on the street and is only driven 10 - 20 miles per day on average, which are failry hard.
Also i have a feeling that the engine is winding down to its final stages. Valve adjustments are needed more frequent, and it leaks a bit of oil (not burns) due to a shitty oil pan and gasket.
Thats Why....
edit..
RJ. Thanks for the link. Its good
[Modified by Cal, 10:00 PM 12/11/2002]
Old Dec 11, 2002 | 06:02 PM
solo-x's Avatar
well as of now no i do not. I change it before and after coming back from the track as everyone should. I will probably track every 2 weeks in the summer and will religiously cahnge it as it is needed.
I do this because my engine is a 92 and although scores good compression, it is a small price to pay to get maximum protection. I just cant afford parts and frequent oil changes, and when driven around ***** footed i will extend it to 2500 -3000 on a change. The fact is that it is rarely driven around lightly as the car isnt comfortable on the street and is only driven 10 - 20 miles per day on average.
Also i have a feelign that the engine is winding down to its final stages. Valve adjustments are needed more frequent, and it leaks a bit of oil (not burns) due to a shitty oil pan and gasket.
Thats Why....
:envy: not of the condition of your car, but that you only have to drive it 10-20 miles a day and you get to track it often enough to change the oil every 1500 miles.
nate-who's engine has 180k+ and is driven 50+ miles a day every day on 600 and 700# springs.
Old Dec 11, 2002 | 07:18 PM
Cal's Avatar
Cal
Dont mis understand me. I drive it little each day beacuse i dont have to. For the winter i put it on stock shocks and springs. For teh summer i will have 8K front 12 K rear.
And i havnt had large amount fo track time. Those numbers are what the car shoudl be doing. Not what it is at this moment. Havnt been to the track or autox course since july
Next year i will have much more time and will run every other weekend or so
Also the engine is still strong and will definetly last for a few more seasons, (hopefully) but maintenence is needed, and oil changing is one of them i like to do often.
Nothing better than warm oil running down your arm.
crazyguy
21
Oct 26, 2007 01:48 PM
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
Behan
Sep 9, 2003 05:10 AM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
mickey513
Oct 5, 2001 10:11 AM
