f22b1 mods
Old Dec 11, 2002 | 02:56 AM
97accordex's Avatar
Default f22b1 mods
Has anyone done any of these mods an f22b1?
1. Throttle body.
I think Gude makes throttle body that fits. Is it worth it or should I just polish my OEM TB or wait until I put in rings etc. and do the whole head.
2. Performance Oil pan.
I have several mods and run at high RPM and drive hard. I guess that answers my own question about whether I need a performance oil pan. Who makes one thats will fit the f22b1? Has anyone used one?? How is install?
3. Injectors
Any idea how much the flow on injectors with 100k miles on them might be degraded? Lets assume better than average care, good gas, original fuel filter, don't let tank get below quarter tank.
4. Fuel filter.
Any tips on changing the fuel filter on a 97 Accord EX? It looks like a bear.
Old Dec 11, 2002 | 11:27 AM
Stew Pidasso's Avatar
Default Re: f22b1 mods (97accordex)
#1. Get a Throttle body off of an H22a or H23a and port match it.
#2. Hmmm, don't know
#3. Your injectors are probably fine but if your worried send them into RC for reconditioning. (Mine had 190K+ miles on them and I was spraying a lot of nitrous)
#4. The fuel filter is a PITA
https://honda-tech.com/zerothread?id=306580
https://honda-tech.com/zerothread?id=317565
https://honda-tech.com/zerothread?id=303978
Hope these help...
Old Dec 11, 2002 | 01:37 PM
97accordex's Avatar
Default Re: f22b1 mods (Stew Pidasso)
Are the H22/H23 throttle bodies direct fits except for the port sizes ??
Thanks for the fuel filter tips!! Really looking forward to it.
Old Dec 11, 2002 | 02:23 PM
ArchAngel Sabastian's Avatar
New User
yes h22/23 TB fit just port match the intake plenum
i perfer a h22 TB as the map sens mounts direct to the TB not just a hose
the fuel filter is difficult it helps if you have a "pit" type area to work in aka jiffy lube and the right tools you will NEEED a crows foot wrench/socket i think its 14mm misa knows for sure.
Old Dec 11, 2002 | 03:32 PM
niedejb's Avatar
I think you'll live without this mod.
Old Dec 11, 2002 | 04:07 PM
New User
Default Re: f22b1 mods (niedejb)
ditto
Old Dec 12, 2002 | 08:07 AM
urbanlegend21's Avatar
New User
Default Re: f22b1 mods (ArchAngel Sabastian)
the only point of a performance oil pan is if you start to have an oil starvation problem in high G corners on a race track. I have run my car 10 times harder and at more G's than you can imagine and am yet to have a starvation problem
Old Dec 12, 2002 | 09:57 AM
97accordex's Avatar
Default Re: f22b1 mods (urbanlegend21)
OK,,, I was worried that I may be seeing some oil starvation at high RPMs. No high g's though. Mostly highway driving that I see the high revs.
Old Dec 12, 2002 | 09:59 AM
97accordex's Avatar
If I have the valve cover off and fuel rail and injectors out will I still need to get at it from under the car with a crows foot??
Old Dec 12, 2002 | 10:06 AM
Did you remove the Intake manifold?
Old Dec 12, 2002 | 10:32 AM
97accordex's Avatar
No,,, have not done any of the work yet. Waiting for parts from Manchester Honda.
Old Dec 12, 2002 | 10:46 AM
TypeSH's Avatar
what are the TB sizes of the F22B1/H23/H22?
Old Dec 12, 2002 | 02:40 PM
sauceman's Avatar
I heard that changing the TB doesn't yield great gains, and really isn't worth the hassle. Is this true, or it may be said only if it was this mod taken alone and not combined with other modifications?
Old Dec 12, 2002 | 02:44 PM
sauceman's Avatar
Default Re: f22b1 mods (sauceman77)
Oops sorry guys, I just found my answer on another thread
Thanks anyway.
Old Dec 12, 2002 | 02:56 PM
Accord_Munch's Avatar
Well .. with the following mods to my F22b1 ..
Greddy EVO
Greddy Header
Bored out TB
B&M Fuel Pressure Regulator
AEM CAI
Skunk2 CAM Gear (-2 degree's)
and a VAFC
I am putting down about 139 hp and 140 of tq to the wheels ... (translates to something like 164 hp and 165 tq)
Not bad over stock
10HBmartian
Nov 19, 2012 03:40 PM
rolledthatho
Feb 20, 2011 05:58 AM
climbengruven
Jan 8, 2007 08:04 AM
N~FaMouSKhMerBoi
Jan 22, 2004 09:14 PM
KooK
May 26, 2003 11:08 PM
